[postgis-users] data extract
Obe, Regina robe.dnd at cityofboston.gov
Tue Nov 13 07:00:44 PST 2007
You can actually go straight from sql statement to shape file
as shown at the bottom of this cheatsheet
http://www.bostongis.com/postgis_quickguide.bqg
Hope that helps,
Regina
From: postgis-users-bounces at postgis.refractions.net
[mailto:postgis-users-bounces at postgis.refractions.net] On Behalf Of
Gregory Williamson
Sent: Tuesday, November 13, 2007 6:48 AM
To: PostGIS Users Discussion; PostGIS Users Discussion
Subject: RE: [postgis-users] data extract
a) Create a table with the select (e.g. create [temp] table my_table as
<select ...>;)
and then either:
b) populate geometry columns with the relevant columns and use the
pgsql2shp to create a shape file
or
c) copy my_table to '/tmp/my_table.unl' with delimiter '|' null '';
depending on what you need the data for ... the first option gets you
the ability to go to ESRI, MMS, etc. The 2nd is more for moving to
another postGIS system.
HTH,
Greg Williamson
Senior DBA
GlobeXplorer LLC, a DigitalGlobe company
Confidentiality Notice: This e-mail message, including any attachments,
is for the sole use of the intended recipient(s) and may contain
confidential and privileged information and must be protected in
accordance with those provisions. Any unauthorized review, use,
disclosure or distribution is prohibited. If you are not the intended
recipient, please contact the sender by reply e-mail and destroy all
copies of the original message.
(My corporate masters made me say this.)
-----Original Message-----
From: postgis-users-bounces at postgis.refractions.net on behalf of Andre
Schoonbee
Sent: Tue 11/13/2007 4:46 AM
To: 'PostGIS Users Discussion'
Thanks!
Now the next question.
I now want to export (dump) the data I have selected.
Andre
George
Pavlov
Sent: Tuesday, November 13, 2007 9:27 AM
select *
from your_table
where unique_id in (
  select max(unique_id)
  from your_table
  group by structure_type
> Behalf Of Andre Schoonbee
> Sent: Monday, November 12, 2007 11:20 PM
> Subject: [postgis-users] data extract
> Importance: High
> I have various tables in my POSTGIS database. Each table
> contains a type field (column) that define the type of
> structure, such as the type of road eg. I want to extract a
> few sample data from each table, but should contain at least
> one of each type so that a developer can test this data
> against a mapserver mapfile. I do not want to dump the entire
> database (to big).That should the sql command looks like
> Regards
> Andre
> Behalf Of Zedler, Doug
> Sent: Wednesday, October 03, 2007 5:03 PM
> To: postgis-users at postgis.refractions.net
> Subject: [postgis-users] Installation Error
> I'm trying to install PostgreSQL and PostGIS to play with it
> and learn about it.  I installed PostgreSQL 8.2.4 just fine.
> I am able to connect using pgAdmin III and such.  When I run
> the PostGIS 1.3.1 installation executable, I get the following error:
> createdb: could not connect to database postgres: FATAL:
> password authentication failed for user "postgres"
> I am able to connect to the postgres database using pgAdmin
> III under the postgres role using the same password I'm
> putting into the installation wizard, and I'm not mixing up
> the password for the database role with the password for the
> local account on my machine.  Any suggestions are appreciated.
> Thanks,
> Douglas B. Zedler
> IT Programmer/Analyst
> Fort Worth Fire Department
> 817.392.8463
postgis-users mailing list
http://postgis.refractions.net/mailman/listinfo/postgis-users
The substance of this message, including any attachments, may be
confidential, legally privileged and/or exempt from disclosure
pursuant to Massachusetts law. It is intended
solely for the addressee. If you received this in error, please
contact the sender and delete the material from any computer.
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20071113/9851bc7c/attachment.html>
