[postgis-users] Database Design
Gustavo Martinez
gumartin at mecon.gov.ar
Tue Nov 13 05:01:18 PST 2007
El Tuesday 13 November 2007 05:27:02 Milo van der Linden escribió:
> I am looking in to this. I contacted the people at fabforce, creators of
> DBDesigner4. When you investigate the program directory, you will see
> that there are ini files containing datatypes and supported databases. I
> would like to get postgres into that. So I asked them if it is possible
> to edit the ini file to make DBDesigner support postgres. I know for
> sure you can reverse engineer it, but supporting the specific datatypes
> for postgres requires some more settings.
There is also an open source fork of DBDesigner4 at
http://sourceforge.net/projects/dbdesigner-fork/
They say that it supports Postgres although I couldn't find the serial type.
> Gustavo Ces schreef:
> > Sorry, i didn´t explain it very well,
> > I don´t see serials or sequences in DBDesigner DataTypeS
> > Column, so i supose i can´t use it in DBD. Actually, i use them in
> > PostGis, but i don´t know how to design a table in DBD and then Save
> > In Database directly ( i suposed geometry columns have to be created
> > by hand, but not taked in count serials or sequences ). So, my
> > question is, is it posible to create in DBD and export to PostGis(
> > avoiding geometry columns) ? Or may i have to create that type of
> > columns "coding by hand", as i do with functions, triggers and other
> > database stuff?
> > Thanks for answering,
> > Gus
> > postgis-users mailing list
> > postgis-users at postgis.refractions.net
> > http://postgis.refractions.net/mailman/listinfo/postgis-users
Lic. Gustavo Martínez
Gestión de Pesquerías
Sub Secretaría de Pesca de la Nación
Paseo Colón 982, Anexo Jardín Pesca
Tel: (54) 11 43492165
Buenos Aires, República Argentina
“Que la tierra se vaya haciendo camino ante tus pasos,
que el viento sople siempre a tus espaldas,
que el sol brille cálido sobre tu cara,
que la lluvia caiga suavemente sobre tus campos y,
hasta tanto volvamos a encontrarnos,
que Dios te lleve en la palma de su mano.”
