[postgis-users] Database Design
Mario Servin
mservin at gmail.com
Tue Nov 13 05:33:51 PST 2007
What about Case Studio?, I am not using it now but once upon a time I used
it for a small project, and it was aware of PostgreSQL 8.1 (I could generate
tables etc.) so I guess it can handle PostGIS extension and serials.
Mario
Bariloche, Argentina
On Nov 13, 2007 10:01 AM, Gustavo Martinez <gumartin at mecon.gov.ar> wrote:
> El Tuesday 13 November 2007 05:27:02 Milo van der Linden escribió:
> > I am looking in to this. I contacted the people at fabforce, creators of
> > DBDesigner4. When you investigate the program directory, you will see
> > that there are ini files containing datatypes and supported databases. I
> > would like to get postgres into that. So I asked them if it is possible
> > to edit the ini file to make DBDesigner support postgres. I know for
> > sure you can reverse engineer it, but supporting the specific datatypes
> > for postgres requires some more settings.
> There is also an open source fork of DBDesigner4 at
> http://sourceforge.net/projects/dbdesigner-fork/
> They say that it supports Postgres although I couldn't find the serial
> type.
> > Gustavo Ces schreef:
> > > Sorry, i didn´t explain it very well,
> > > I don´t see serials or sequences in DBDesigner DataTypeS
> > > Column, so i supose i can´t use it in DBD. Actually, i use them in
> > > PostGis, but i don´t know how to design a table in DBD and then Save
> > > In Database directly ( i suposed geometry columns have to be created
> > > by hand, but not taked in count serials or sequences ). So, my
> > > question is, is it posible to create in DBD and export to PostGis(
> > > avoiding geometry columns) ? Or may i have to create that type of
> > > columns "coding by hand", as i do with functions, triggers and other
> > > database stuff?
> > > Thanks for answering,
> > > Gus
> > > _______________________________________________
> > > postgis-users mailing list
> > > postgis-users at postgis.refractions.net
> > > http://postgis.refractions.net/mailman/listinfo/postgis-users
> Lic. Gustavo Martínez
> Gestión de Pesquerías
> Sub Secretaría de Pesca de la Nación
> Paseo Colón 982, Anexo Jardín Pesca
> Tel: (54) 11 43492165
> Buenos Aires, República Argentina
> "Que la tierra se vaya haciendo camino ante tus pasos,
> que el viento sople siempre a tus espaldas,
> que el sol brille cálido sobre tu cara,
> que la lluvia caiga suavemente sobre tus campos y,
> hasta tanto volvamos a encontrarnos,
> que Dios te lleve en la palma de su mano."
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20071113/d3ca08ff/attachment.html>
