[postgis-users] Best way to
louvy.joseph at gmail.com
Tue Nov 20 01:23:35 PST 2007
Thanks Paul. We are already using multiple instances of geoservers with
single postgis server. (We are starting new geoserver dynamically based
on the load). At this point, I don't have enough load to saturate the
database but I am just preparing myself to a condition where too many
geoservers (that would mean too many users behind them in turn) would
swamp the single database instance.
Are there any benchmark numbers for postgresql/postgis on how many
simultaneous transactions it can handle? 80% of our data is wfs or wms
but 20% is going to be wfs-t updates.
Can somebody please point me to any benchmark numbers for
postgresql/postgis system?
Thanks again
Louvy
Paul Ramsey wrote:
> louvy.joseph at gmail.com wrote:
>> We are developing a solution using geoserver with postgis postresql
>> server. Out database is going to be huge and our projection is that
>> number of simultaneous users will be too huge to be handled by single
>> database.
> And you think you're going to bottleneck at the database? :) Better
> check out Geoserver more closely. :)
>> What are the best practices currently available to handle this?
>> Please do comment on some of the open thoughts we have:
>> 1) Does it make sense to split the database based on geography? For
>> example, single database for each continent or a country. But we have
>> concerns on changes needed to our client for handling the region
>> boundaries and the features crossing region boundaries.
> If your features are going to be crossing boundaries, then no,
> partitioning on geography is not wise. There are probably other
> variables you can partition on. Anything that has a hard
> non-overlapping domain is a candidate (user id, for example).
>> 2) We are also thinking of multi-master replication solutions. Can
>> somebody give opinion of a) Postgres-R b) PgCluster c) Bucardo -
>> d) Sequoia ? Which of them is stable? Which is more mature and has
>> more community? Which is better: synchronous versus asynchronous
>> replication?
> None of the multi-master technologies for postgres are particularly
> mature. But there is no guarantee you actually need multi-master.
> Having a single update server and multiple query servers might serve
> just as well.
>> 3) BTW, how many users a single postgres database instance (say on a
>> 2GHz Pentium 2GB memory system) can handle?
> This depends entirely on what they are doing, so an answer is not
> possible with this much information.
> P.
