[postgis-users] CentOS 4.5 postgis-1.1.0.spec patch
Rob Nagler nagler at bivio.biz
Tue Nov 20 06:44:01 PST 2007
Aha!  http://postgis.refractions.net/rpms/ is out of date.  I just
downloaded the srpm assuming it was the latest.  It hasn't been
updated since 1/4/06, and binary RPMs for Fedora have not been updated
either.
I've attached a patch for the postgis.spec in the 1.3.1 tarball.  This
builds on Centos 4.5 without javabuild & gcj_support.  The Version had
to be changed to 1.3.1 and some dependencies had to be moved around in
the appropriate %if sections.  The config.patch failed so I removed it
along with the postgis-javamakefile.patch, which I didn't need.
If you need help creating an autobuilder for the SRPM from the
tarball, let me know.
PostGIS is a great resource.  Thanks!
Cheers,
Rob
*** postgis-1.3.1.spec~	2007-11-20 07:21:14.000000000 -0700
--- postgis-1.3.1.spec	2007-11-20 07:33:10.000000000 -0700
*** 10,21 ****
  Group:		Applications/Databases
  Source0:	http://postgis.refractions.net/download/%{name}-%{version}.tar.gz
  Source4:	filter-requires-perl-Pg.sh
- Patch1:		postgis-configure.patch
- Patch2:		postgis-javamakefile.patch
  URL:		http://postgis.refractions.net/
  BuildRoot:	%{_tmppath}/%{name}-%{version}-%{release}-root-%(%{__id_u} -n)
! BuildRequires:	postgresql-devel, proj-devel, geos-devel, byacc, proj-devel, flex, postgresql-jdbc
  Requires:	postgresql, geos, proj
  %description
--- 10,19 ----
  %description
*** 32,38 ****
  License:	LGPL
  Requires:	postgis
! BuildRequires:  ant >= 0:1.6.2, junit >= 0:3.7
  %if %{gcj_support}
  BuildRequires:		gcc-java
--- 30,36 ----
  License:	LGPL
  Requires:	postgis
! BuildRequires:  ant >= 0:1.6.2, junit >= 0:3.7, postgresql-jdbc
  %if %{gcj_support}
*** 58,65 ****
  %prep
  %setup -q
- %patch1 -p0
- %patch2 -p0
  %build
  %configure
--- 56,61 ----
*** 105,113 ****
--- 101,111 ----
  %clean
  rm -rf %{buildroot}
+ %if %{gcj_support}
  %post -p %{_bindir}/rebuild-gcj-db
  %postun -p %{_bindir}/rebuild-gcj-db
+ %endif
  %files
  %defattr(-,root,root)
