Sorry, I solved it. Re: [postgis-users] no coveredby in liblwgeom.1.3.so
Lela Prashad
lela.prashad at gmail.com
Tue Nov 20 13:01:50 PST 2007
Steve,
How did you solve this? I had the same problem running 1.3.1 PostGIS
with PSQL 8.2.5, Proj 4.5.0, and GEOS 2.2.3. When I went down to 1.2.1
PostGIS there were no problems with "coveredby" or anything else.
Additionally, I'm using the "GIS for Web Developers" Pragmatic
Programmers book by Scott Davis for instructions on how to install
these.
Thanks for the help,
Lela
Steve Sweet wrote:
>Sorry folks. When I posted my question before I hadn't caught that the
>subject line had changed in the posting thread I referenced. The
>original poster made a comment in the subsequent threat that clicked in
>my head and it appears I've fixed the problem.
>It must be Friday afternoon ...
Steve Sweet wrote:
> I should have include my configure statement:
> ./configure --with-pgsql --with-geos --with-proj=/usr/local/proj
> Steve Sweet wrote:
>> I'm trying to build postgis-1.3.1 on a Centos 5.0 system (same as
>> RedHat EL 5.0). I built the prerequisite's immediately prior,
>> including postgresql and when it comes to the step of applying
>> lwpostgis.sql, I get exactly the same behavior referenced in this
>> posting from August 17th
>> (http://postgis.refractions.net/pipermail/postgis-users/2007-August/016749.html)
>> : the script runs fine until near the end when I get this message:
>> psql:lwpostgis.sql:4093: ERROR: could not find function "coveredby"
>> in file "/usr/lib/pgsql/liblwgeom.so.1.3"
>> Every transaction after that step fails.
>> The linker shows it knows of the library
>> [root at dev postgis-1.3.1]# /sbin/ldconfig -v | grep geom
>> liblwgeom.so.1 -> liblwgeom.so.1.3
>> and since most of the script runs fine it seems that the library is
>> being used.
>> This is the first build on a virgin system so there are no previous
>> library versions hanging around:
>> [root at dev pgsql]# ls -l liblwgeom*
>> lrwxrwxrwx 1 root root 16 Oct 5 12:48 liblwgeom.so ->
>> liblwgeom.so.1.3
>> lrwxrwxrwx 1 root root 16 Oct 5 12:48 liblwgeom.so.1 ->
>> liblwgeom.so.1.3
>> -rwxr-xr-x 1 root root 999008 Oct 5 12:48 liblwgeom.so.1.3
>> and there is no "coveredby" or anything close in liblwgeom.so.1.3
>> [root at dev pgsql]# nm -o liblwgeom.so.1.3 | grep -i cover
>> I'm stuck. The answer in the previous thread was essentially "wait a
>> bit then re-grab the source and try again" but that was quite some
>> time ago. Has any one experienced and overcome this? Thanks.
>> Steve
>> postgis-users mailing list
>> postgis-users at postgis.refractions.net
>> http://postgis.refractions.net/mailman/listinfo/postgis-users
Lela Prashad
Co-Executive Director, NiJeL
Voice. 602.412.1553
Email. lprashad at nijel.org
Web. www.nijel.org
