[postgis-users] Problem with Intersection(Geometry, Geometry)
Matt Doughty
matt.doughty at geograma.com
Tue Nov 20 23:16:12 PST 2007
Hi all,
I'm having some problems with the intersection function that I've been
trying to use as a Cookie cutter command.
I've been executing the following script:
SELECT
INTERSECTION(<cookie>.the_geom, <cookie-cutter>.the_geom) AS
the_geom
INTO
<output>
FROM
<cookie>,
<cookie-cutter>
WHERE
<cookie>.the_geom && <cookie-cutter>.the_geom
AND
intersects(<cookie>.the_geom, <cookie-cutter>.the_geom);
The problem it gives me is that polygons which need to be cut don't turn
out right. The output retuns to the geometry column a GeometryCollection
for the polygon in question. This is composed of one polygon, which is
what I want, and a collection of linestrings, each of which represents a
segment of the boundary of the cutting polygon, which obviously I don't
want.
Has anybody come across this and how can I solve the problem?
Cheers,
Matt
Matt Doughty
GEOGRAMA S.L.
Tel.: +34 945 13 13 72 652 77 14 15
Fax: +34 945 23 03 40
www.geograma.com
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20071121/0bd3e04c/attachment.html>
Type: image/jpeg
Desc: image001.jpg
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20071121/0bd3e04c/attachment.jpg>
