[postgis-users] distance between multiple polygons
Martin Davis
mbdavis at refractions.net
Wed Nov 21 08:41:10 PST 2007
Finding the maximum distance between two polygons from a set is going to
be very slow. Also, there's no built-in function to do this, so you'd
have to code it up yourself.
It would be faster to find the bounding box of all the geometries and
use that to determine a visibility area.
Kevin Kempfer wrote:
> Hello!
> I have to find out which polygons have the longest distance between any
> two polygons (or points of them) from a set of multiple polygons. For
> example:
> I have 5 polygons.
> Find out where's the biggest distance between them and give back the two
> points.
> I need this to be able to zoom in/out my map application to a zoom level
> where all polygons are visible to the user.
> Is this possible using build-in postgis functions or do I have to write
> my own?
> Best regards,
> Kevin
> postgis-users mailing list
Martin Davis
Senior Technical Architect
Refractions Research, Inc.
(250) 383-3022
