[postgis-users] Query performanace against huge point table
Kevin Neufeld
kneufeld at refractions.net
Fri Nov 23 09:14:23 PST 2007
Hi Santosh,
Hmmm. I think the collecting-points-by-some-grid solution was rather
particular to our use case - we didn't have any attribution on our
points, we were just interested in the z value of the points
themselves. This clearly won't work for you if you retain different
attribution on every point.
As for the 2163 SRID, it's the Lambert Azimuthal Equal-Area projection
for the U.S. coordinate reference system. Regina has some notes on it
here:
http://postgis.refractions.net/pipermail/postgis-users/2007-August/016668.html
as well as some references to SRID descriptions here:
http://postgis.refractions.net/pipermail/postgis-users/2007-June/016008.html
As Paul originally posted here
(http://postgis.refractions.net/pipermail/postgis-users/2007-July/016262.html),
I agree that you will probably get better performance by storing your
original geometry in 2163, rather than in lat / long, avoiding your
transforms.
Cheers,
Kevin
Santosh Gaikwad wrote:
> Hi Kevin,
> How I can query the table which has been created by using
> CREATE TABLE new_pt_tbl AS
> SELECT collect(geom) AS my_multi_pt
> FROM pt_tbl
> GROUP BY ST_SnapToGrid(geom, <grid_size>);
> As it contains only my_multi_pt geometry. I want to run the following
> query against this table.
> Select *
> from table
> where
> st_dwithin(
> transform(the_geom,2163),
> transform(GeomFromText('POINT(-122.0527 37.323)',4326),2163),
> 1000
> And the above table also needs to be in 2163 srid projection. Can you
> explain me in detail?
> I am working on whole USA data. Initially I thought to separate data
> state wise into different tables but it will not be useful as we are
> finding out the locations from a given point with a certain radius.
> Currently I have stored whole data in a table but it really affecting
> the performance. The functional index and clustering have helped me in
> increasing the performance.
> I would appreciate your help on this issue.
> Thanks & Regards,
> Santosh Gaikwad
> Senior Software Developer
> Saama Technologies (India) Pvt. Ltd.,
> Unit No.101-102, First floor,
> Weikfield IT CITI INFO PARK,
> Weikfield estates,
> Pune Nagar Road,
> Pune - 411 014. India
> Phone : +91 20 66071397
> Mobile: +91-9422005927
> E-mail :Santosh.Gaikwad at saama.com
> http://www.saama.com
> -----Original Message-----
> From: postgis-users-bounces at postgis.refractions.net
> [mailto:postgis-users-bounces at postgis.refractions.net] On Behalf Of
> Kevin Neufeld
> Sent: Wednesday, November 21, 2007 10:45 PM
> To: PostGIS Users Discussion
> Subject: Re: [postgis-users] Query performanace against huge point table
> Yes, clustering your table based on your GIST index does help because it
> physically orders the rows in your table based on the spatial index.
> The disk head won't have far to move to retrieve the next page.
> I've worked with a table of about 170 million points (not as large as
> your 300m :) ) before and I was running into the same problem. We were
> able to significantly speed up index queries by grouping points in sets
> of about 100 - 200 based on some arbitrary grid. Instead of having an
> index entry for every point, now you have one entry for every 100
> points, reducing the size of your index by 100! Of course, you've added
> the complexity of having to deal with MultiPoints, but depending on your
> use cases, this may or may not be an issue.
> ie.
> FROM pt_tbl
> Cheers,
> Kevin
>> Hi Kevin,
>> Thank you very much for your help. I created now the functional index
> of
>> "transform(the_geom,2163)" on my geometry column. It is faster now. I
>> would like to know whether clustering of indices helps in speeding up
>> the query.
>> Thanks & Regards,
>> Santosh Gaikwad
>> Weikfield estates,
>> Pune Nagar Road,
> postgis-users mailing list
