[postgis-users] "make check" failures w/ 1.3.1 on Mac OS 10.5
John Cartwright john.c.cartwright at comcast.net
Sun Nov 25 11:22:07 PST 2007
Hello All,
Trying to compile v1.3.1 on leopard.  Compilation seems to go OK, but
35 out of 37 tests fail on the "make check" prior to installation.
For example:
loader/Point. failed (running shp2pgsql: /var/folders/v1/
v1z9PHeJEvGQIvBCSUU0QE+++TI/-Tmp-//loader.err)
loader.err contains:
../loader/shp2pgsql: shape (.shp) or index files (.shx) can not be
opened.
The configuration summary is listed below.  Any ideas on what I'm
doing wrong here?
Thanks!
--john
Config Summary:
HOST_OS: darwin9.1.0
    PGSQL: /usr/local/pgsql/bin/pg_config
     GEOS: /usr/local/geos-2.2.3/bin/geos-config (with C-API)
           (ldflags: -L/usr/local/geos-2.2.3/lib)
     PROJ: prefix=/usr/local/proj-4.5.0 libdir=/usr/local/proj-4.5.0/lib
    ICONV: 1 -liconv
  PORTNAME: darwin
    PREFIX: /usr/local/postgis-1.3.1
   EPREFIX: ${prefix}
       DOC: ${prefix}/share/doc
      DATA: ${datarootdir}
       MAN: ${datarootdir}/man
       BIN: ${exec_prefix}/bin
       EXT: ${exec_prefix}/lib (${exec_prefix}/lib)
