[postgis-users] "make check" failures w/ 1.3.1 on Mac OS 10.5
John Cartwright john.c.cartwright at comcast.net
Sun Nov 25 21:13:52 PST 2007
Thanks for looking into this William and for your suggestion.  I've
implemented it, but am still getting 12 failures (all loader tests),
complaining that:
../loader/shp2pgsql: shape (.shp) or index files (.shx) can not be
opened.
I've confirmed that the shapefiles are present and should be
accessible and that the test database (postgis_reg) is not present.
Any ideas on what might be wrong?
Thanks again for your help!
--john
On Nov 25, 2007, at 4:09 PM, William Kyngesburye wrote:
> And once more... there was some leftover junk from the previous
> failed tests (a bunch of errors about relation already exists).
> After those were cleared out, all tests succeeded!
> On Nov 25, 2007, at 5:02 PM, William Kyngesburye wrote:
>> Sorry to keep replying to myself.  I think I see the problem:
>> get_uint32().  Leopard's libSystem now includes its own
>> get_uint32() (and get_int32()), so this is used in postgis instead
>> of the one in lwgeom_api.c.
>> I can't find ANY reference to this in the Leopard headers or the
>> Xcode documentation, or in Apple's forums or mailing list
>> archives.  So I can't tell if it's compatible, it's certainly not
>> usable if there is no header declaration of it.
>> So, renaming get_int32() and get_uint32() in Postgis did the trick
>> (I used pgis_get_int32 and pgis_get_uint32).  They're in these files:
>> liblwgeom.h
>> lwcurve.c
>> lwgeom_api.c
>> lwgeom_pg.c
>> lwline.c
>> lwpoint.c
>> lwpoly.c
>> I now have 5/37 fails.  Time to check on those.
> William Kyngesburye <kyngchaos*at*kyngchaos*dot*com>
> http://www.kyngchaos.com/
> "Those people who most want to rule people are, ipso-facto, those
> least suited to do it."
> - A rule of the universe, from the HitchHiker's Guide to the Galaxy
> postgis-users mailing list
