[postgis-users] How can I make geo-reference
Amrita p amritaprasad1 at rediffmail.com
Tue Nov 27 02:14:23 PST 2007
Thanks for ur reply.
But I didn't get your point.
My point is - I have shape file but it contains geometry in meters form. I want to convert it into lat/log format.
I am using openmap as front end and in front end we can display only that shape file which is lat/log format.
Any idea abt this..
regards,
Amrita
On Tue, 27 Nov 2007 Dave Potts wrote :
>Amrita p wrote:
>You need what is called a projection file, it defines the projection to be used with a given a shape file, see http://en.wikipedia.org/wiki/Shapefile for the details.
>The following is a shape file for the uk ordnace survey, if you shape file is called foo, then you need to create a file called foo.shp, with this content
>PROJCS["British_National_Grid",GEOGCS["GCS_OSGB_1936",DATUM["D_OSGB_1936",SPHEROID["Airy_1830",6377563.396,299.3249646]],PRIMEM["Greenwich",0.0],UNIT["Degre
>e",0.0174532925199433]],PROJECTION["Transverse_Mercator"],PARAMETER["False_Easting",400000.0],PARAMETER["False_Northing",-100000.0],PARAMETER["Central_Merid
>ian",-2.0],PARAMETER["Scale_Factor",0.999601272],PARAMETER["Latitude_Of_Origin",49.0],UNIT["Meter",1.0]]
>If you need the text for a different projection system, have a look at the contents of the table spatial_ref_sys, you should find something that matches in there.
>D.
>>  Hi All!
>>I have  file with extension .shp, .dbf, .shx but this shape file in not geo-reference.
>>I want to make the shape file geo-reference...
>>How can I do the above..
>>If any body has any idea abt this please help me..
>>Thanks in advance.
>>Amrita
>>Reliance Mobile <http://adworks.rediff.com/cgi-bin/AdWorks/click.cgi/www.rediff.com/signature-home.htm/1050715198@Middle5/1960866_1953803/1960349/1?PARTNER=3&OAS_QUERY=null%20target=new%20>
>>_______________________________________________
>>postgis-users mailing list
>>postgis-users at postgis.refractions.net
>>http://postgis.refractions.net/mailman/listinfo/postgis-users
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20071127/e7327213/attachment.html>
