[postgis-users] Invalid Geometry Error
Gerry James
gerry.james at carteryx.com
Tue Nov 27 14:46:04 PST 2007
I am trying to create a polygon for the extents of each of a number of
tables and use the geometries to populate an index table. The SQL I have
been using is:
INSERT INTO index_survey (tablename,the_geom) VALUES ('survey_20040812'
,GeometryFromText('POLYGON(455700 5609025, 462650 5609025, 462650 5613490,
455700 5613490, 455700 5609025)',26911));
which throws out an 'invalid geometry' error. To create the spatial table
in the first place I used:
CREATE TABLE index_survey (gid serial PRIMARY KEY, tablename varchar(25));
SELECT
AddGeometryColumn('public','index_survey','the_geom','26911','POLYGON',2);
I have tried using this SQL both from pgAdmin and using ASP with no success.
Does anyone have any suggestions?
Thanks Gerry
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20071127/12e304c6/attachment.html>
