[postgis-users] Invalid Geometry Error
Kevin Neufeld
kneufeld at refractions.net
Tue Nov 27 14:53:26 PST 2007
The WKT representation of a POLYGON contains two brackets, not one - an
outer ring and zero or more interior rings.
-- Kevin
Gerry James wrote:
> I am trying to create a polygon for the extents of each of a number of
> tables and use the geometries to populate an index table. The SQL I
> have been using is:
> INSERT INTO index_survey (tablename,the_geom) VALUES
> ('survey_20040812' ,GeometryFromText('POLYGON(455700 5609025, 462650
> 5609025, 462650 5613490, 455700 5613490, 455700 5609025)',26911));
> which throws out an ‘invalid geometry’ error. To create the spatial
> table in the first place I used:
> CREATE TABLE index_survey (gid serial PRIMARY KEY, tablename varchar(25));
> SELECT AddGeometryColumn('public','index_survey’,'the_geom','26911','POLYGON',2);
> I have tried using this SQL both from pgAdmin and using ASP with no
> success.
> Does anyone have any suggestions?
> Thanks Gerry
> postgis-users mailing list
