[postgis-users] Except
Kevin Neufeld
kneufeld at refractions.net
Wed Nov 28 08:04:14 PST 2007
Sorry, my bad... I misread your question.
You might be able to write a plpgsql function that went looking at the
system tables for a list of all your columns for a given table and then
build a query using the columns of your choice.
-- Kevin
Kevin Neufeld wrote:
> How about,
> SELECT col1, col2, col3 FROM my_tbl
> EXCEPT
> (SELECT col1, col2, col3 FROM my_tbl LIMIT 1);
> -- Kevin
> Matt Doughty wrote:
>> Hi,
>> Is there a way of selecting all fields except one in particular? I’d
>> like to create a query that says something like: select * except
>> field01. The thing is the query needs to be valid for a number of
>> different tables, each with a different set of fields apart from one
>> (gid), which I don’t want to select.
>> Cheers,
>> Matt
>> Matt Doughty
>> GEOGRAMA S.L.
>> Tel.: +34 945 13 13 72 652 77 14 15
>> Fax: +34 945 23 03 40
>> www.geograma.com
>> postgis-users mailing list
>> postgis-users at postgis.refractions.net
>> http://postgis.refractions.net/mailman/listinfo/postgis-users
