[postgis-users] Except
Matt Doughty
matt.doughty at geograma.com
Wed Nov 28 08:12:10 PST 2007
Thanks for the ideas. At the moment I'm trying to go with the 'array as text' suggested by George although I have to admit I haven't got very far yet.
Matt
PS: Sorry for sending a SQL question to the PostGIS list- shan't happen again (although I must say the members of this list have been particulary helpful!).
Matt Doughty
GEOGRAMA S.L.
Tel.: +34 945 13 13 72 652 77 14 15
Fax: +34 945 23 03 40
www.geograma.com
-----Mensaje original-----
De: postgis-users-bounces at postgis.refractions.net [mailto:postgis-users-bounces at postgis.refractions.net] En nombre de Kevin Neufeld
Enviado el: miƩrcoles, 28 de noviembre de 2007 17:04
Para: PostGIS Users Discussion
Asunto: Re: [postgis-users] Except
Sorry, my bad... I misread your question.
You might be able to write a plpgsql function that went looking at the
system tables for a list of all your columns for a given table and then
build a query using the columns of your choice.
-- Kevin
Kevin Neufeld wrote:
> How about,
> SELECT col1, col2, col3 FROM my_tbl
> EXCEPT
> (SELECT col1, col2, col3 FROM my_tbl LIMIT 1);
> -- Kevin
> Matt Doughty wrote:
>> Hi,
>> Is there a way of selecting all fields except one in particular? I'd
>> like to create a query that says something like: select * except
>> field01. The thing is the query needs to be valid for a number of
>> different tables, each with a different set of fields apart from one
>> (gid), which I don't want to select.
>> Cheers,
>> Matt
>> Matt Doughty
>> GEOGRAMA S.L.
>> www.geograma.com
>> postgis-users mailing list
>> postgis-users at postgis.refractions.net
>> http://postgis.refractions.net/mailman/listinfo/postgis-users
