[postgis-users] Got VACUUM reccomendation in newly-created postGIStable
Per-Olof Norén
pelle at alma.nu
Thu Nov 29 05:40:10 PST 2007
Gregory Williamson skrev:
> Per-Olof wrote:
>> kreshna_iceheart at yahoo.com skrev:
>>> And if I run
>>> VACUUM ANALYZE, there won't be anything bad happen,
>> nope, do It!
>> Seriously, this is exactly the correct way to go.
>> vacuum analyze updates the index statistics.
> Nit-picking department chimes in:
> ANALYZE updates statistics for indexed columns
> VACUUM cleans out dead tuples from deletes & updates and prevents table bloat and transaction id wraparound failure.
> So ANALYZE (which is fast and relatively light-weight) whenever data distributions change
> and
> VACUUM periodically for the whole database, and vacuum tables that have updates and deletes. Or use autovacuum if you on a recent release of PostgreSQL (8.2 seems fairly robust but your experience may differ on what sort of processing you do).
Admittedly, I pressed send to fast. Greg is correct. :-)
cheers,
Per-Oof
