[postgis-users] Cleaning polygons, function documentation and a buffering problem (bug?) (longish)
Martin Davis
mbdavis at refractions.net
Thu Nov 29 08:51:51 PST 2007
Rolf,
Sorry about the late reply.
Your approach of handling holes separately and then subtracting them
from the containing polygon seems like a fine solution. Someday we hope
to provide a native PostGIS function will perform cleaning - it will of
course handle holes as well, probably using an equivalent technique.
As for documentation, we'd like to see much better doc as well, and have
a few internal discussions about how to improve it. As always,
resources and time are very limiting factors. In the meantime, feel
free to add documentation to the wiki yourself, to help out everybody.
We'd be happy to review whatever you contribute, as well.
Glad your buffer problem went away - if only all bugs were like that...
Martin
Rolf A. de By wrote:
> Greetings list,
> Martin Davis/Kevin Neufeld provided a few weeks ago a technique to
> clean non-hole polygons from
> topological errors. In my PostGIS function list their technique now
> features as the following function:
> CREATE OR REPLACE FUNCTION cleanpoly_nohole(geometry)
> RETURNS geometry AS
> $BODY$
> select st_buildarea(uniongeom) as geom
> from ( select st_union(ringgeom, st_startpoint(ringgeom)) as uniongeom
> from ( select st_exteriorring($1::geometry) as ringgeom
> ) as ring
> ) as fixed_ring
> $BODY$
> LANGUAGE 'sql' STABLE STRICT;
> See their original contributions for further explanation. This
> technique has also made it into the wiki. There,
> it is written that "this may not create the expected topology if the
> polygon contains holes." I believe this should
> read "this will not . . . " So, it begs the question what to do with
> polygons that have holes. I believe the following
> works nicely, but I would appreciate informed comments. The
> philosophy is to repair the outer polygon, and the
> holes separately, and then determine their difference:
> CREATE OR REPLACE FUNCTION cleanpoly(geometry)
> RETURNS geometry AS
> $BODY$
> select st_difference(
> cleanpoly_nohole($1::geometry),
> st_collect(
> cleanpoly_nohole(
> st_makepolygon(st_interiorringn($1,n)))))
> from generate_series(1,st_numinteriorrings($1)) n ;
> $BODY$
> If this works, the next challenge is cleaning multipolygons.
> In general, I find it difficult to assess what some of the more
> advanced postgis functions actually do, and I find myself
> experimenting a lot before making progress. I would appreciate any
> references for deepening understanding of functions
> beyond the online manual. I have especially battled with collect,
> union and buffer recently. But similar questions can be
> posed for instance on polygonize. See one example problem below.
> I would, possibly naively, expect that a buffer operation on a polygon
> with a positive second argument always returns
> another polygon. Not so. See below real life example of a polygon
> that when buffered with value 15.0 gives us a
> multipolygon.
> "POLYGON((714.103 691.448,718.28 680.791,723.529 670.828,735.946
> 650.734,741.534 643.564,743.456 642.132,755.886 628.959,768.711
> 614.556,781.448 599.061,790.854 583.975,794.955 575.398,796.672
> 570.676,798.261 564.386,799.47 551.874,798.977 542.831,798.641
> 502.569,798.126 496.618,797.128 479.322,797.694 475.348,797.338
> 462.208,796.228 458.223,794.151 455.166,791.173 453.476,740.495
> 430.063,683.268 403.624,654.936 387.98,651.863 386.284,633.721
> 374.736,553.295 323.328,529.519 307.93,477.499 274.242,330.223
> 178.866,323.818 189.765,299.791 175.088,269.819 214.939,298.751
> 233.579,289.75 253.256,340.273 277.111,343.51 281.428,337.242
> 298.22,309.767 368.698,323.552 373.714,329.658 361.494,319.098
> 357.065,350.654 280.095,361.081 263.681,357.098 260.717,372.841
> 235.538,436.141 276.203,410.421 315.518,374.397 292.474,360.3
> 326.201,380.311 334.391,386.153 319.782,414.786 330.706,390.006
> 392.687,395.293 394.583,381.808 426.063,368.122 458.655,311.366
> 435.146,303.302 425.776,288.84 421.292,286.146 428.064,283.88
> 433.761,269.744 469.302,254.538 508.521,254.274 510.133,310.026
> 533.366,325.919 539.932,332.466 542.638,382.588 563.345,387.912
> 565.545,392.954 567.628,439.578 585.259,462.115 525.738,462.625
> 520.627,461.605 516.539,397.755 490.986,379.111 484.349,383.426
> 478.412,474.885 512.961,447.108 588.097,476.048 599.005,524.184
> 614.068,531.969 616.761,563.932 629.03,605.771 647.025,638.199
> 661.907,649.533 622.053,615.53 612.78,628.819 564.054,636.005
> 566.014,633.376 575.654,640.598 577.623,667.347 479.54,672.605
> 480.974,674.804 472.912,689.913 477.033,695.103 457.998,682.204
> 454.481,678.532 467.94,663.389 463.81,668.59 444.741,695.231
> 452.007,701.732 428.168,719.365 432.978,714.575 450.54,729.42
> 454.589,713.916 514.387,687.436 507.164,665.386 585.132,696.139
> 593.26,680.908 650.895,650.154 642.767,644.063 664.598,699.23
> 689.915,709.353 693.956,711.519 693.775,712.692 693.118,714.103
> 691.448),(608.479 579.933,580.072 572.982,600.562 489.249,654.485
> 502.444,644.038 545.137,625.727 540.657,615.685 581.696,608.479
> 579.933),(556.661 510.789,584.304 443.146,604.636 448.842,611.27
> 450.7,599.405 485.234,579.45 550.524,544.394 540.273,522.945
> 531.348,525.518 525.164,508.635 518.141,574.869 358.435,578.787
> 360.065,584.617 346.569,593.37 350.211,577.827 387.567,580.973
> 388.876,534.147 501.422,556.661 510.789),(301.911 505.413,297.714
> 510.076,268.586 498.749,283.823 461.743,279.374 459.912,289.081
> 436.335,293.938 438.335,292.329 442.242,327.382 456.675,317.295
> 481.174,321.988 483.106,301.911 505.413))"
> What we get is a multipolygon with three nested shells. Is this a bug
> of the
> buffer function? I am using: PostGIS version "1.3 USE_GEOS=1
> USE_PROJ=1 USE_STATS=1" and GEOS "3.0.0rc4-CAPI-1.3.3"
> regards,
> Rolf de By
> postgis-users mailing list
Martin Davis
Senior Technical Architect
Refractions Research, Inc.
(250) 383-3022
