[postgis-users] Problem using GeomFromEWKT with a long LINESTRING
Randy George
rkgeorge at cadmaps.com
Thu Nov 29 17:09:07 PST 2007
I am having a problem loading a long LINESTRING into a table:
select postgis_full_version()
"POSTGIS="1.3.1" GEOS="3.0.0rc4-CAPI-1.3.3" PROJ="Rel. 4.5.0, 22 Oct 2006"
USE_STATS"
The following command will create the new record but does not add the_geom
field. There is no error message. If I shorten the LINESTRING all works as
expected? I've tried it on a couple of PostGIS systems with the same
results.
insert into track ("the_geom") values(
GeomFromEWKT('SRID=4269;LINESTRING(-111.90102383494377 35.15539236366749
2130.0,-111.90076441504061 35.155294756405056 2156.0,-111.89992362633348
35.15645384788513 2158.0,-111.89894068054855 35.154357785359025
2157.0,-111.8990724440664 35.154491434805095 2152.0,-111.89869827590883
35.15350262168795 2153.0,-111.89799830317497 35.15475898515433
2152.0,-111.89676524139941 35.1538841240108 2154.0,-111.8959382828325
35.153554170392454 2152.0,-111.895482391119 35.154451662674546
2150.0,-111.89550686627626 35.155860618688166 2150.0,-111.89468384720385
35.15504392795265 2148.0,-111.89386342652142 35.155171332880855
2151.0,-111.89402737654746 35.155834634788334 2174.0,-111.89337492920458
35.1547295646742 2174.0,-111.89352555200458 35.15537849161774
2173.0,-111.89291073940694 35.15671456698328 2174.0,-111.89221856184304
35.15662848483771 2179.0,-111.89042667858303 35.15583601780236
2182.0,-111.89062524586916 35.15624077990651 2178.0,-111.89116512425244
35.15709602739662 2177.0,-111.89084778539836 35.15727581921965
2179.0,-111.89192452467978 35.15779000706971 2179.0,-111.89113897271454
35.15605780296028 2180.0,-111.89244068227708 35.15592654235661
2180.0,-111.89359763637185 35.15613173134625 2174.0,-111.89319840632379
35.154905333183706 2173.0,-111.89338381402194 35.15462273731828
2171.0,-111.89371783286333 35.15523449052125 2174.0,-111.89294225536287
35.155262486077845 2173.0,-111.89327551983297 35.15670731663704
2174.0,-111.89300520345569 35.15695315785706 2172.0,-111.89197615720332
35.15743180643767 2177.0,-111.89270135946572 35.15916271135211
2174.0,-111.8934724945575 35.16106255352497 2179.0,-111.89323822036386
35.1608623098582 2182.0,-111.89239625819027 35.160291753709316
2181.0,-111.89171439036727 35.15963884536177 2180.0,-111.89226826652884
35.15958562027663 2177.0,-111.8930892739445 35.16092479694635
2183.0,-111.8930839933455 35.160568985156715 2181.0,-111.89307301305234
35.160386175848544 2181.0,-111.89227044582367 35.16006611287594
2178.0,-111.89356829971075 35.1608001999557 2180.0,-111.89376167021692
35.16136396676302 2182.0,-111.89237865619361 35.16004968434572
2183.0,-111.89226516522467 35.160230146721005 2181.0,-111.89267336390913
35.16064090188593 2182.0,-111.89161816611886 35.16005337238312
2182.0,-111.89334978349507 35.160495140589774 2178.0,-111.89394649118185
35.161482696421444 2183.0,-111.893439469859 35.160989672876894
2184.0,-111.89290034584701 35.16023534350097 2180.0,-111.89223264344037
35.160091342404485 2182.0,-111.89235921017826 35.16059069428593
2184.0,-111.89311249181628 35.160889592953026 2182.0,-111.89277931116521
35.16079538036138 2184.0,-111.89339311793447 35.160701838321984
2182.0,-111.89285349100828 35.160919348709285 2182.0,-111.89163384027779
35.16026250086725 2181.0,-111.89283538609743 35.16068763099611
2182.0,-111.89211085438728 35.16002085059881 2179.0,-111.89280688762665
35.16034858301282 2178.0,-111.8927161116153 35.1605628663674
2181.0,-111.89209434203804 35.16022595576942 2180.0,-111.89326462335885
35.16045599710196 2179.0,-111.89291216433048 35.16075003426522
2181.0,-111.89279389567673 35.16067547723651 2184.0,-111.89346872270107
35.16098707448691 2182.0,-111.89265634864569 35.16063771676272
2180.0,-111.89329940825701 35.16044308897108 2180.0,-111.8936313316226
35.16066554468125 2180.0,-111.8926214799285 35.160538936033845
2181.0,-111.89255953766406 35.160458092577755 2179.0,-111.8931394815445
35.16075003426522 2182.0,-111.8932740110904 35.160600962117314
2182.0,-111.89284343272448 35.160405579954386 2182.0,-111.89455334097147
35.16060238704085 2180.0,-111.89338004216552 35.16079165041447
2181.0,-111.89304367639124 35.1604965236038 2180.0,-111.89194162376225
35.16035583335906 2180.0,-111.89132421277463 35.160638387314975
2182.0,-111.89281929284334 35.16033844090998 2179.0,-111.89314710907638
35.160597525537014 2183.0,-111.89313294366002 35.160450926050544
2180.0,-111.89282574690878 35.1604912430048 2180.0,-111.89210255630314
35.16074475366622 2183.0,-111.89267076551914 35.160604482516646
2181.0,-111.8922945857048 35.16046358272433 2182.0,-111.89290990121663
35.15988502185792 2183.0,-111.89390525221825 35.15911573078483
2176.0,-111.89369235187769 35.16042276285589 2183.0,-111.8922771513462
35.16083917580545 2181.0,-111.89122773706913 35.160622922703624
2181.0,-111.89270504750311 35.16065657604486 2179.0,-111.89277084544301
35.160466390661895 2181.0,-111.89407758414745 35.160222980193794
2181.0,-111.89401530660689 35.16051127575338 2181.0,-111.89319270662963
35.16067283693701 2181.0,-111.89432803541422 35.160140208899975
2182.0,-111.89301241189241 35.16061990521848 2182.0,-111.89268694259226
35.16047167126089 2180.0,-111.89434555359185 35.16016091220081
2184.0,-111.89221981912851 35.16100802924484 2180.0,-111.89289221540093
35.16068033874035 2183.0,-111.89182251691818 35.160975214093924
2180.0,-111.89247680827975 35.16102341003716 2182.0,-111.89173366874456
35.16141019295901 2182.0,-111.89336780458689 35.16046555247158
2180.0,-111.89302339218557 35.16066952608526 2180.0,-111.89240732230246
35.16146262176335 2185.0,-111.89407867379487 35.15988942235708
2181.0,-111.89252726733685 35.161154167726636 2183.0,-111.89314627088606
35.16071671620011 2181.0,-111.89300050958991 35.160548533312976
2181.0,-111.89338892698288 35.16032335348427 2179.0,-111.89152923412621
35.16153080854565 2180.0,-111.89346738159657 35.160200600512326
2179.0,-111.89275885932148 35.16105287242681 2183.0,-111.89221445471048
35.16135063953698 2181.0,-111.893101176247 35.160849946551025
2183.0,-111.89299304969609 35.160531853325665 2180.0,-111.89435988664627
35.15922666527331 2179.0,-111.89358590170741 35.160021940246224
2180.0,-111.89348850399256 35.160754728130996 2185.0,-111.89228720963001
35.16140227206051 2183.0,-111.89294409938157 35.16060402151197
2179.0,-111.89295566640794 35.160506749525666 2180.0,-111.89255115576088
35.16146949492395 2181.0,-111.892871260643 35.161159322597086
2182.0,-111.89335238188505 35.160507671535015 2183.0,-111.892448393628
35.16126422211528 2180.0,-111.89390307292342 35.159635534510016
2182.0,-111.89275978133082 35.16126623377204 2183.0,-111.89264218322933
35.16089864540845 2180.0,-111.89309941604733 35.1602718885988
2183.0,-111.89319253899157 35.16015684697777 2180.0,-111.89308986067772
35.16055712476373 2182.0,-111.89306748099625 35.16042100265622
2183.0,-111.892926748842 35.160559890791774 2181.0,-111.8930892739445
35.160658420063555 2181.0,-111.8936643563211 35.15949677210301
2181.0,-111.89354441128671 35.160104082897305 2182.0,-111.89287897199392
35.16045440454036 2179.0,-111.89345204271376 35.160346110351384
2182.0,-111.8933168426156 35.160492584109306 2181.0,-111.89342161640525
35.15963540878147 2180.0,-111.89277302473783 35.16157255042344
2185.0,-111.89295893535018 35.15983791556209 2180.0,-111.89281962811947
35.16098300926387 2180.0,-111.89323947764933 35.159971145913005
2180.0,-111.89287804998457 35.159947257488966 2178.0,-111.89284351654351
35.159501591697335 2178.0,-111.89316437579691 35.15977852977812
2181.0,-111.89316890202463 35.1607684744522 2181.0,-111.8925258424133
35.16153038945049 2179.0,-111.89324492588639 35.16100165899843
2181.0,-111.89290646463633 35.16114704310894 2181.0,-111.89273103140295
35.16059941146523 2180.0,-111.89312984235585 35.160358934663236
2183.0,-111.89280613325536 35.16013568267226 2180.0,-111.8928543291986
35.16111728735268 2182.0,-111.89319740049541 35.160450926050544
2182.0,-111.89315431751311 35.16106469091028 2181.0,-111.89289229921997
35.16044246032834 2180.0,-111.89294409938157 35.160663574934006
2180.0,-111.89288064837456 35.16062095295638 2180.0,-111.89305616542697
35.16082274727523 2181.0,-111.8930078856647 35.16062296461314
2183.0,-111.8933739233762 35.1607053168118 2183.0,-111.89259750768542
35.159496227279305 2179.0,-111.89329379238188 35.1614799303934
2183.0,-111.89332631416619 35.16081771813333 2181.0,-111.89272600226104
35.15994876623154 2183.0,-111.89318222925067 35.16089914832264
2181.0,-111.89312749542296 35.16105911694467 2179.0,-111.89253154210746
35.16019209288061 2178.0,-111.89331483095884 35.16160008497536
2179.0,-111.89321056008339 35.161246452480555 2180.0,-111.89277428202331
35.16012306790799 2180.0,-111.89282071776688 35.16044996213168
2181.0,-111.89282650128007 35.16040310729295 2180.0,-111.89318105578423
35.16096582636237 2181.0,-111.89303772523999 35.16066629905254
2179.0,-111.89309220761061 35.16115504782647 2179.0,-111.89250472001731
35.159823624417186 2181.0,-111.8935522902757 35.161190503276885
2180.0,-111.89286765642464 35.15999700408429 2181.0,-111.8926989287138
35.16053663101047 2179.0,-111.8926664069295 35.16050469595939
2182.0,-111.89308944158256 35.161170973442495 2178.0,-111.89337677322328
35.1605567894876 2184.0,-111.89285759814084 35.16029104124755
2180.0,-111.89247479662299 35.160239450633526 2181.0,-111.89287251792848
35.15998371876776 2184.0,-111.89350962638855 35.160948098637164
2182.0,-111.89236004836857 35.16000366769731 2183.0,-111.89287536777556
35.16077916137874 2179.0,-111.8935176730156 35.160722876898944
2181.0,-111.89252324402332 35.160284880548716 2182.0,-111.89339948818088
35.16097060404718 2183.0,-111.89266506582499 35.16029104124755
2180.0,-111.89367047511041 35.1609817519784 2181.0,-111.89330066554248
35.160755943506956 2180.0,-111.89357182011008 35.16097940504551
2182.0,-111.89336403273046 35.16078779473901 2181.0,-111.89360442571342
35.16088376753032 2179.0,-111.89312221482396 35.16049136873335
2182.0,-111.89273522235453 35.160786411724985 2180.0,-111.89241679385304
35.16014645341784 2185.0,-111.89291124232113 35.16044497489929
2184.0,-111.89379402436316 35.16103162430227 2180.0,-111.8928921315819
35.160610475577414 2182.0,-111.89310788176954 35.16028492245823
2183.0,-111.89300084486604 35.16030210535973 2184.0,-111.89325925894082
35.160641823895276 2182.0,-111.8917316570878 35.16049141064286
2181.0,-111.89313562586904 35.16076604370028 2178.0,-111.8922721222043
35.160984308458865 2178.0,-111.89343938603997 35.16068327240646
2178.0,-111.89358866773546 35.16038357745856 2181.0,-111.89299489371479
35.160307344049215 2184.0,-111.8930617813021 35.158341326750815
2172.0,-111.89376862719655 35.158858322538435 2176.0,-111.89319346100092
35.160804726183414 2180.0,-111.89292817376554 35.16052175313234
2183.0,-111.89310293644667 35.1605377625674 2183.0,-111.89230548217893
35.1605602260679 2181.0,-111.89289573580027 35.16044531017542
2183.0,-111.89297913573682 35.160430683754385 2183.0,-111.89310050569475
35.16076147556305 2181.0,-111.89227153547108 35.1613588957116
2181.0,-111.89350769855082 35.16013429965824 2183.0,-111.89293010160327
35.16083909198642 2181.0,-111.89303873106837 35.16068851109594
2182.0,-111.89268317073584 35.16115098260343 2179.0,-111.89314333721995
35.16100216191262 2179.0,-111.8927060533315 35.160734821110964
2181.0,-111.89329664222896 35.16037527937442 2181.0,-111.89278400503099
35.161168961785734 2182.0,-111.89319572411478 35.16014838125557
2182.0,-111.89305557869375 35.16073448583484 2180.0,-111.89281141385436
35.160765373148024 2182.0,-111.89376669935882 35.1596069522202
2180.0,-111.8931009247899 35.160087905824184 2182.0,-111.89259038306773
35.16088167205453 2182.0,-111.89305557869375 35.15865673776716
2173.0,-111.89256004057825 35.15991230495274 2175.0,-111.8931878451258
35.15985979232937 2182.0,-111.89317611046135 35.16062862239778
2181.0,-111.89305817708373 35.161076970398426 2180.0,-111.89294585958123
35.16063604038209 2184.0,-111.89345221035182 35.16086105257273
2180.0,-111.89286313019693 35.160881713964045 2182.0,-111.89299313351512
35.159962638281286 2182.0,-111.89289858564734 35.16044669318944
2183.0,-111.89314970746636 35.15838021878153 2172.0,-111.89305004663765
35.16078846529126 2182.0,-111.89305851235986 35.160501594655216
2181.0,-111.89292029477656 35.1607034727931 2183.0,-111.89278786070645
35.16072819940746 2182.0,-111.89271393232048 35.16151630785316
2182.0,-111.89317929558456 35.16023148782551 2180.0,-111.8932010885328
35.16071462072432 2181.0,-111.89284007996321 35.16134632285684
2182.0,-111.89277394674718 35.160805019550025 2181.0,-111.89294837415218
35.16165041830391 2180.0,-111.89286857843399 35.160791063681245
2183.0,-111.89296287484467 35.16098443418741 2184.0,-111.89284670166671
35.16186185181141 2183.0,-111.89337199553847 35.16146190930158
2181.0,-111.89301266334951 35.160642326809466 2182.0,-111.8928419239819
35.16063407063484 2182.0,-111.89290185458958 35.160181783139706
2182.0,-111.89308357425034 35.16047502402216 2180.0,-111.89288693480194
35.159841729328036 2179.0,-111.89299221150577 35.160617139190435
2178.0,-111.89304828643799 35.160667933523655 2180.0,-111.89324341714382
35.161131117492914 2183.0,-111.89262575469911 35.16034514643252
2181.0,-111.89267688430846 35.160366939380765 2182.0,-111.89364432357252
35.161782475188375 2182.0,-111.8928905390203 35.16052883584052
2180.0,-111.89305172301829 35.16077077947557 2181.0,-111.89275743439794
35.16054949723184 2182.0,-111.89328323118389 35.16103480942547
2180.0,-111.89379326999187 35.1613208418712 2180.0,-111.89352639019489
35.160970855504274 2180.0,-111.89198638312519 35.15902533195913
2181.0,-111.89297913573682 35.16047020442784 2181.0,-111.89262106083333
35.159863899461925 2180.0,-111.8929835781455 35.160553394816816
2180.0,-111.89345539547503 35.160971065051854 2181.0,-111.89308759756386
35.16069735400379 2181.0,-111.89401463605464 35.1611006911844
2179.0,-111.89292071387172 35.160254035145044 2181.0,-111.89284611493349
35.160640524700284 2181.0,-111.89251092262566 35.16024762298912
2180.0,-111.89288827590644 35.160105004906654 2179.0,-111.89292130060494
35.16020864713937 2180.0,-111.89313177019358 35.16094763763249
2180.0,-111.89254386350513 35.16021078452468 2182.0,-111.8926780577749
35.16035952139646 2181.0,-111.89282448962331 35.16064605675638
2181.0,-111.89316705800593 35.16110396012664 2182.0,-111.89308483153582
35.16030797269195 2181.0,-111.89218260347843 35.15998246148229
2179.0,-111.89164004288614 35.16022243537009 2183.0,-111.89227815717459
35.16025960911065 2182.0,-111.89339613541961 35.16058449167758
2178.0,-111.89189611002803 35.15984927304089 2180.0,-111.89337300136685
35.15934262890369 2173.0,-111.89236155711114 35.15958247706294
2174.0,-111.89363040961325 35.160911050625145 2181.0,-111.89284787513316
35.160430683754385 2175.0,-111.89309790730476 35.16074902843684
2181.0,-111.89381640404463 35.16089868731797 2184.0,-111.89326931722462
35.160645679570735 2179.0,-111.89250698313117 35.16007411759347
2184.0,-111.89237714745104 35.160271637141705 2180.0,-111.89359688200057
35.15837384853512 2173.0,-111.89310067333281 35.16061064321548
2182.0,-111.89232023432851 35.16039053443819 2179.0,-111.89334399998188
35.16101117245853 2182.0,-111.89456507563591 35.16084739007056
2178.0,-111.89380508847535 35.16066361684352 2178.0,-111.89273966476321
35.160402855835855 2180.0,-111.893460592255 35.160489859990776
2181.0,-111.89308147877455 35.16055980697274 2180.0,-111.89323545433581
35.16075703315437 2180.0,-111.89146360382438 35.160104585811496
2180.0,-111.89281610772014 35.16049367375672 2180.0,-111.89365781843662
35.1609360286966 2182.0,-111.8928300216794 35.160753219388425
2183.0,-111.89282306469977 35.16061273869127 2180.0,-111.8934238795191
35.160927856341004 2183.0,-111.89278040081263 35.16066411975771
2181.0,-111.89305507577956 35.16074915416539 2183.0,-111.89314031973481
35.1605663029477 2182.0,-111.89281795173883 35.16088548582047
2183.0,-111.89140384085476 35.16070066485554 2183.0,-111.89336948096752
35.16058746725321 2183.0,-111.89341021701694 35.16063046641648
2180.0,-111.89327644184232 35.16043579671532 2178.0,-111.89280906692147
35.160637465305626 2179.0,-111.89242785796523 35.1604193681851
2182.0,-111.89233481884003 35.160443927161396 2182.0,-111.89266389235854
35.160538223572075 2181.0,-111.89350300468504 35.1603926718235
2179.0,-111.8923157081008 35.16047808341682 2180.0,-111.89242517575622
35.160879199393094 2182.0,-111.89266674220562 35.160455452278256
2180.0,-111.89319807104766 35.16087308060378 2183.0,-111.8931321054697
35.16065686941147 2182.0,-111.89314492978156 35.160688259638846
2183.0,-111.89321097917855 35.160499163903296 2181.0,-111.89392779953778
35.16066923271865 2183.0,-111.89354181289673 35.16025701072067
2180.0,-111.89265039749444 35.16070460435003 2181.0,-111.89307795837522
35.160499582998455 2180.0,-111.89378555864096 35.16017201822251
2179.0,-111.8939355108887 35.16016443260014 2181.0,-111.89217556267977
35.160823334008455 2180.0,-111.89361037686467 35.160505659878254
2180.0,-111.89314392395318 35.160551592707634 2180.0,-111.89332807436585
35.16022717114538 2180.0,-111.89469943754375 35.16003044787794
2180.0,-111.89242509193718 35.16105647664517 2183.0,-111.89314727671444
35.16095572616905 2182.0,-111.89331466332078 35.160648613236845
2182.0,-111.89331726171076 35.160500588826835 2182.0,-111.8924846034497
35.16070447862148 2179.0,-111.89262013882399 35.16086859628558
2182.0,-111.89341206103563 35.16023220028728 2181.0,-111.89246348105371
35.16058210283518 2179.0,-111.89440397545695 35.159612190909684
2182.0,-111.89293219707906 35.16023266129196 2180.0,-111.8924486450851
35.1609754236415 2183.0,-111.89264989458025 35.16089885495603
2182.0,-111.89358145929873 35.16036170069128 2182.0,-111.89243003726006
35.161074958741665 2183.0,-111.89428947865963 35.15977190807462
2183.0,-111.89259868115187 35.161005766130984 2181.0,-111.89201043918729
35.16173453070223 2181.0,-111.89273086376488 35.160945542156696
2180.0,-111.89260899089277 35.161075461655855 2182.0,-111.89196936786175
35.161582441069186 2181.0,-111.89303311519325 35.160004422068596
2179.0,-111.89336009323597 35.16018253751099 2182.0,-111.89335280098021
35.16051098238677 2182.0,-111.89244889654219 35.16126392874867
2181.0,-111.89390349201858 35.15963876154274 2181.0,-111.89324844628572
35.16029280144721 2182.0,-111.89312397502363 35.16041006427258
2180.0,-111.89310042187572 35.159782553091645 2179.0,-111.89319295808673
35.16015999019146 2179.0,-111.89406677149236 35.15909532085061
2181.0,-111.89306094311178 35.1609090808779 2183.0,-111.89292037859559
35.16007466241717 2179.0,-111.89308952540159 35.16065816860646
2183.0,-111.89366469159722 35.159496436826885 2182.0,-111.89354474656284
35.15961550176144 2182.0,-111.89287913963199 35.161430686712265
2182.0,-111.89296396449208 35.16034925356507 2180.0,-111.89282876439393
35.16098049469292 2181.0,-111.89244529232383 35.16109981108457
2179.0,-111.89328356646001 35.159290744923055 2179.0,-111.89277302473783
35.16108401119709 2181.0,-111.89295901916921 35.16032590996474
2181.0,-111.89281954430044 35.161474398337305 2182.0,-111.8932393938303
35.16046261880547 2183.0,-111.89287796616554 35.16043860465288
2181.0,-111.89333343878388 35.16047129407525 2182.0,-111.89316437579691
35.15978150535375 2181.0,-111.8931688182056 35.15979487448931
2181.0,-111.89300713129342 35.16055691521615 2183.0,-111.89275651238859
35.16100115608424 2181.0,-111.8930734321475 35.160376536659896
2180.0,-111.89290629699826 35.160170048475266 2181.0,-111.89273086376488
35.16157565172762 2180.0,-111.89312925562263 35.160362999886274
2181.0,-111.89280563034117 35.16013610176742 2180.0,-111.89284661784768
35.161152868531644 2181.0,-111.89317745156586 35.16102148219943
2182.0,-111.89264377579093 35.160607416182756 2179.0,-111.89289221540093
35.16043793410063 2182.0,-111.89294451847672 35.16066131182015
2181.0,-111.89288827590644 35.160624431446195 2180.0,-111.89305717125535
35.16082387883216 2180.0,-111.89300880767405 35.16062740702182
2180.0,-111.89288651570678 35.16022151336074 2180.0,-111.89259842969477
35.1594972750172 2182.0,-111.8932946305722 35.16050436068326
2183.0,-111.89283882267773 35.16033043619245 2182.0,-111.89321525394917
35.160441705957055 2182.0,-111.89318315126002 35.16138865146786
2180.0,-111.8926468770951 35.160571709275246 2178.0,-111.89350903965533
35.16165817156434 2183.0,-111.89282733947039 35.16062795184553
2181.0,-111.89272994175553 35.16027096658945 2182.0,-111.8932634498924
35.16061257105321 2182.0,-111.89292381517589 35.16129427123815
2178.0,-111.89330980181694 35.16093929763883 2181.0,-111.89282725565135
35.16040742397308 2182.0,-111.89255023375154 35.16017910093069
2179.0,-111.89441772177815 35.1613139687106 2182.0,-111.89553427509964
35.16213267110288 2182.0,-111.89592327922583 35.16080141533166
2182.0,-111.8968622200191 35.16033068764955 2171.0,-111.89775095321238
35.16048994380981 2172.0,-111.89880011603236 35.160878780297935
2172.0,-111.8990467954427 35.16102584078908 2171.0,-111.89946689642966
35.16169471666217 2171.0,-111.89950251951814 35.16148223541677
2172.0,-111.89992572180927 35.1616638712585 2171.0,-111.89972455613315
35.16202605329454 2174.0,-111.89969371072948 35.16273709014058
2171.0,-111.9002299848944 35.16318053472787 2172.0,-111.90117345191538
35.163402990438044 2174.0,-111.90148148685694 35.163440625183284
2171.0,-111.90163739025593 35.16342620830983 2149.0,-111.90202111378312
35.163778834976256 2152.0,-111.90270071849227 35.164290885441005
2151.0,-111.90233258530498 35.163211966864765 2151.0,-111.90408624708652
35.16428631730378 2151.0,-111.9052183907479 35.16419248189777
2150.0,-111.90579213202 35.163893373683095 2144.0,-111.90681832842529
35.163705074228346 2144.0,-111.90715712495148 35.16380398068577
2142.0,-111.90696744248271 35.16368680167943 2140.0,-111.9064705632627
35.1629969291389 2144.0,-111.9070287141949 35.16412978526205
2141.0,-111.90757772885263 35.16514252871275 2135.0,-111.90777068026364
35.16537424642593 2137.0,-111.90705897286534 35.165730686858296
2136.0,-111.90778518095613 35.16688290517777 2134.0,-111.90741637721658
35.16671740449965 2133.0,-111.90876049920917 35.16778903082013
2136.0,-111.90970907919109 35.16808093059808 2085.0,-111.91170263104141
35.168334231711924 2084.0,-111.91412273794413 35.16881053335965
2085.0,-111.91291498951614 35.17086967360228 2089.0,-111.91146483644843
35.16993718687445 2090.0,-111.91193229518831 35.16914090607315 2086.0)'));
thanks
randy
