[postgis-users] "make check" failures w/ 1.3.1 on Mac OS 10.5
Mark Cave-Ayland mark.cave-ayland at ilande.co.uk
Fri Nov 30 00:10:07 PST 2007
On Thu, 2007-11-29 at 23:10 -0700, John Cartwright wrote:
> Hi Mark,
> Using the hourly svn snapshot, the build went fine, but "make check"
> is still failing 12 out of 37:
> ../loader/shp2pgsql: shape (.shp) or index files (.shx) can not be
> opened.
> --john
Hi John,
Hmmm I'm not sure why the "make check" is failing because it can't open
the loader test files - it's good to see that the build works which is
the important thing.
The only thing I can think of is filesystem permissions - what do the
permissions for the loader/ directory look like? Are the shape files
actually present?
Kind regards,
Mark.
ILande - Open Source Consultancy
http://www.ilande.co.uk
