[postgis-users] "make check" failures w/ 1.3.1 on Mac OS 10.5
John Cartwright
john.c.cartwright at comcast.net
Fri Nov 30 18:00:44 PST 2007
Well, the problem seems to be with the shp2pgsql utility - trying to
run it w/ a different shapefile in a different directory produces
similar results:
jcc$ /usr/local/postgis-1.3.1/bin/shp2pgsql cities.shp test.cities
/usr/local/postgis-1.3.1/bin/shp2pgsql: shape (.shp) or index files
(.shx) can not be opened.
Any suggestions on how to proceed from here?
Thanks!
--john
On Nov 30, 2007, at 1:10 AM, Mark Cave-Ayland wrote:
> On Thu, 2007-11-29 at 23:10 -0700, John Cartwright wrote:
>> Hi Mark,
>> Using the hourly svn snapshot, the build went fine, but "make check"
>> is still failing 12 out of 37:
>> ../loader/shp2pgsql: shape (.shp) or index files (.shx) can not be
>> opened.
>> --john
> Hi John,
> Hmmm I'm not sure why the "make check" is failing because it can't
> open
> the loader test files - it's good to see that the build works which is
> the important thing.
> The only thing I can think of is filesystem permissions - what do the
> permissions for the loader/ directory look like? Are the shape files
> actually present?
> Kind regards,
> Mark.
> ILande - Open Source Consultancy
> http://www.ilande.co.uk
> postgis-users mailing list
