[postgis-users] "make check" failures w/ 1.3.1 on Mac OS 10.5
William Kyngesburye
woklist at kyngchaos.com
Fri Nov 30 20:04:58 PST 2007
I finally had a chance to try it. Builds and all tests run.
I can't think of what might be going on on your system John. There
might be something helpful in your console or system logs.
On Nov 30, 2007, at 2:10 AM, Mark Cave-Ayland wrote:
> On Thu, 2007-11-29 at 23:10 -0700, John Cartwright wrote:
>> Hi Mark,
>> Using the hourly svn snapshot, the build went fine, but "make check"
>> is still failing 12 out of 37:
>> ../loader/shp2pgsql: shape (.shp) or index files (.shx) can not be
>> opened.
>> --john
> Hi John,
> Hmmm I'm not sure why the "make check" is failing because it can't
> open
> the loader test files - it's good to see that the build works which is
> the important thing.
> The only thing I can think of is filesystem permissions - what do the
> permissions for the loader/ directory look like? Are the shape files
> actually present?
> Kind regards,
> Mark.
William Kyngesburye <kyngchaos*at*kyngchaos*dot*com>
http://www.kyngchaos.com/
[Trillian] What are you supposed to do WITH a maniacally depressed
robot?
[Marvin] You think you have problems? What are you supposed to do if
you ARE a maniacally depressed robot? No, don't try and answer, I'm
50,000 times more intelligent than you and even I don't know the
answer...
- HitchHiker's Guide to the Galaxy
