[postgis-users] Re: PROJ Projection Issues
mchapman at texelinc.com
Sun Oct 21 17:20:03 PDT 2007
Brian,
You can get those files from gdal.org as well.
Martin
Sent via BlackBerry by AT&T
-----Original Message-----
Date: Sun, 21 Oct 2007 17:57:01
To:postgis-users at postgis.refractions.net
Subject: [postgis-users] Re: PROJ Projection Issues
Paul:
In the Windows install, there is the "libproj.dll" in the BIN directory
but no other files with which have names that imply 'grid' or 'nad'.
Unfortunately, we don't have an older Windows install in the office to
compare to...
Thanks,
Brian
Are there grid files in the proj directory?
On 19-Oct-07, at 2:36 PM, Brian Timoney wrote:
>/ Paul:
/>/ Thanks for the quick reply. The more recent version with dubious
/>/ results was using the standard PostGIS Windows installer.
/>/ Brian
/>/ Proj has the funny build process where you have to untar the
/>/ nadcon grids into the source tree before building. If you forget
/>/ that step, your proj won't have the grids available for conversion.
/>/ P
/>/ On 19-Oct-07, at 2:03 PM, Brian Timoney wrote:
/>>/ / Was whatever does the datum shifts between NAD27 and NAD83 not
/>/ />/ included in more recent builds of PROJ? Is it a 4.5 issue?/
/>/ _______________________________________________
/>/ postgis-users mailing list
/>/ postgis-users at postgis.refractions.net <http://postgis.refractions.net/mailman/listinfo/postgis-users>
/>/ http://postgis.refractions.net/mailman/listinfo/postgis-users
The Timoney Group
518 17th Street
Suite 980
Denver, CO 80202
Ph: (303) 929-3722
Fax: (303) 571-4304
www.thetimoneygroup.com
