[postgis-users] where to register to submit bug?
ivan minčík
ivan.mincik at gmail.com
Mon Oct 29 15:25:35 PDT 2007
I made pg_dump from the table. You can download it here:
http://disk.jabbim.cz/hrach@jabber.cz/bug_db.tar.gz
You have to:
1. change my database user (called ivo) to Your user
2. createdb somedb
3. psql -U youruser -f bug_db.sql somedb
try
select simplify(the_geom,100) from bug_table where icutjcpa =
'8601232244003';
is it ok that way?
thanks
Ivan
Mark Cave-Ayland wrote:
> On Mon, 2007-10-29 at 18:46 +0100, ivan minčík wrote:
>> my detail are:
>> Debian Etch stable.
>> select postgis_full_version();
>> POSTGIS="1.1.6" GEOS="2.2.3-CAPI-1.1.1" PROJ="Rel. 4.5.0, 22 Oct 2006"
>> USE_STATS
>> (1 row)
>> but the same problem was when I tried the newest version of postgis.
>> BUT ->
>> when I try
>> select simplify('MULTIPOLYGON(((-333399.63 -1270249.25,-333416.78
>> -1270247.43,-333415.54 -1270231.88,-333411.49 -1270209.38)),((-333408.1
>> -1270235.32,-333408.8 -1270244.32,-333401.1 -1270245.02,-333400.5
>> -1270236.12,-333408.1 -1270235.32)),((-333397.27
>> -1270210.4)),((-333397.58 -1270214.37)))', 500);
>> ERROR: geometry contains non-closed rings
>> result is the same as Yours
>> but when i try to
>> select simplify(the_geom,1000) from kataster where icutjcpa =
>> '8601232244003'; server closed the connection unexpectedly
>> This probably means the server terminated abnormally
>> before or while processing the request.
>> The connection to the server was lost. Attempting reset: Failed.
>> icutjcpa = '8601232244003' is that object
>> select astext(the_geom) from kataster where icutjcpa =
>> '8601232244003';
>> astext
>> MULTIPOLYGON(((-333399.63 -1270249.25,-333416.78 -1270247.43,-333415.54
>> -1270231.88,-333411.49 -1270209.38)),((-333408.1 -1270235.32,-333408.8
>> -1270244.32,-333401.1 -1270245.02,-333400.5 -1270236.12,-333408.1
>> -1270235.32)),((-333397.27 -1270210.4)),((-333397.58 -1270214.37)))
>> (1 row)
> Strange. Can you provide a self-contained .sql file that creates the
> table, loads the geometry and exhibits the bug? Also, if you pg_dump
> your existing database and then pg_restore into a new database, does the
> problem still occur?
> Kind regards,
> Mark.
