[postgis-users] where to register to submit bug?
ivan minčík
ivan.mincik at gmail.com
Wed Oct 31 02:45:46 PDT 2007
hi, Mark
SELECT version();
version
PostgreSQL 8.1.9 on i486-pc-linux-gnu, compiled by GCC cc (GCC) 4.1.2
20061115 (prerelease) (Debian 4.1.1-21)
(1 row)
Ivan
Mark Cave-Ayland wrote:
> On Mon, 2007-10-29 at 23:25 +0100, ivan minčík wrote:
>> I made pg_dump from the table. You can download it here:
>> http://disk.jabbim.cz/hrach@jabber.cz/bug_db.tar.gz
>> You have to:
>> 1. change my database user (called ivo) to Your user
>> 2. createdb somedb
>> 3. psql -U youruser -f bug_db.sql somedb
>> try
>> select simplify(the_geom,100) from bug_table where icutjcpa =
>> '8601232244003';
>> is it ok that way?
>> thanks
>> Ivan
> Hi Ivan,
> Yes, that's fine - not sure exactly when I'll get a chance to look at
> it, but I'll see what I can do. Can you also confirm the version of
> PostgreSQL used to produce the dump? (SELECT version())
> Many thanks,
> Mark.
