[postgis-users] Mac OS X development - anyone have a Mac available for testing?
Webb Sprague
webb.sprague at gmail.com
Sun Sep 2 16:58:05 PDT 2007
I built postgis, and installed proj, geos, and postgresql from fink.
With postgis, I give it a special prefix in ./configure, but that is
all. (I don't fiddle with optimizations or anything).
I don't think I will be using your binary, even though it is an
excellent service for the community.
-W
On 9/2/07, William Kyngesburye <woklist at kyngchaos.com> wrote:
> Webb,
> Did you see my questions a week ago about your OSX setup?
> - do you build GEOS and PROJ yourself or use binaries (like my
> frameworks)?
> - do you build your own Postgres or use binaries (I also have one,
> but there are a couple others out there)?
> - what configure flags are you using for PostGIS?
> - if you do use binaries for anything, even if it's not directly
> related to postgres or postgis, do you use Fink or Macports? There
> are occassional little things in these that can cause trouble when
> building from source.
> While it would be nice to figure out where the problem is, so others
> can avoid problems, have you tried my PostGIS binary?
> On Sep 2, 2007, at 5:24 PM, Webb Sprague wrote:
> > Hi all,
> > Actually, I rebuilt from scratch and it *worked* fine but didn't pass
> > the regressions because when the regessions test the error messages,
> > that crapped out.
> > -W
> William Kyngesburye <kyngchaos*at*kyngchaos*dot*com>
> http://www.kyngchaos.com/
> First Pogril: Why is life like sticking your head in a bucket filled
> with hyena offal?
> Second Pogril: I don't know. Why IS life like sticking your head in
> a bucket filled with hyena offal?
> First Pogril: I don't know either. Wretched, isn't it?
> -HitchHiker's Guide to the Galaxy
