[postgis-users] libiconv problem
Dave Potts
dave.potts at pinan.co.uk
Sat Sep 8 10:51:43 PDT 2007
Jeff Stubbs wrote:
> Hi,
> I'm working within the MacPorts system on OS X. The portfile for
> postgis is currently at version 1.2.1, and I'm trying to update it to
> the latest (1.3.1). PostGIS builds and installs but is linking to the
> libiconv library in /usr/lib, instead of the libiconv port in
> /opt/local/lib. The MacPorts system tries to be self contained with
> it's dependencies, so I have been trying to tweak the install to rely
> on the MP install of libiconv. PostGIS recognizes that proj, geos, and
> postgresql are installed in the /opt/local directories.
> I saw a thread from December-2005 that another user was having a
> similar problem with a Debian system, and I've been cautiously trying
> the suggestions to workaround the issues, but with no luck. I'm a
> relative nu-bee with modifying makefiles, so, no doubt, I'm missing
> something blindingly obvious. Can a more experienced user or
> developer, throw some light on the issue for me?
> Thanks for your time,
> Jeff
> postgis-users mailing list
Hi Jeff
Check out redo_prebinding or have a look at some off the envronment
options listed under dyld( man dyld for details)
redo_prebinding allows to changes the settings for a binary program, the
settings for dyld effect where a given program looks for files.
Dave.
Type: text/x-vcard
Desc: not available
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20070908/58c9d58d/attachment.vcf>
