[postgis-users] Bounding Circle instead of Bounding Box
Paul Ramsey
pramsey at refractions.net
Sun Sep 9 12:54:48 PDT 2007
Indeed:
SELECT *
FROM mytable
WHERE
ST_DWithin(mytable.the_geom, ST_SetSRID(MakePoint($x, $y), $srid),
$distance);
P.
On 9-Sep-07, at 11:25 AM, Shane Spencer wrote:
> I don't understand how the Distance() and Intersects() and Contains
> () function wouldn't work for this?
> Are X and Y radius the same?
> On 9/9/07, postgis at jochem.name <postgis at jochem.name > wrote:Hi,
> what I want to do is finding certain features in some distance
> around a
> certain point. Those features should be located in some corridor
> between X
> and Y km around this point. Currently I've solved this problem by
> computing two bounding boxes of X and Y km around the point and
> taking the
> difference of those. So far so good.
> But I don't want to have some quadratic box but a real circle - is
> there
> any way to achieve this?
> Best regards,
> Rainer
> postgis-users mailing list
