[postgis-users] Bounding Circle instead of Bounding Box
Shane Spencer
shane at bogomip.com
Sun Sep 9 17:22:23 PDT 2007
indeed, you could even pregenerate the correct ellipse geometry then use
that with ST_DWithin. At least if you have an ellipse instead of a true
circle.
Shane
On 9/9/07, Paul Ramsey <pramsey at refractions.net> wrote:
> Indeed:
> SELECT *
> FROM mytable
> WHERE
> ST_DWithin(mytable.the_geom, ST_SetSRID(MakePoint($x, $y), $srid),
> $distance);
> P.
> On 9-Sep-07, at 11:25 AM, Shane Spencer wrote:
> > I don't understand how the Distance() and Intersects() and Contains
> > () function wouldn't work for this?
> > Are X and Y radius the same?
> > On 9/9/07, postgis at jochem.name <postgis at jochem.name > wrote:Hi,
> > what I want to do is finding certain features in some distance
> > around a
> > certain point. Those features should be located in some corridor
> > between X
> > and Y km around this point. Currently I've solved this problem by
> > computing two bounding boxes of X and Y km around the point and
> > taking the
> > difference of those. So far so good.
> > But I don't want to have some quadratic box but a real circle - is
> > there
> > any way to achieve this?
> > Best regards,
> > Rainer
> > postgis-users mailing list
> > postgis-users at postgis.refractions.net
> > http://postgis.refractions.net/mailman/listinfo/postgis-users
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20070909/020523cc/attachment.html>
