[postgis-users] ST_<function> vs <function>
    Obe, Regina
    robe.dnd at cityofboston.gov
    Mon Sep 10 03:58:57 PDT 2007
Steve,
Just to add to what Mark said.  There is a little bit more going on than simply a renaming.
Most if not all of the ST relation functions have automatic index use enabled in them.
For example
the old within is really closer to the hidden _ST_Within  and the new
ST_Within function is equivalent to writing the old
geom1 && geom2 AND Within(geom1, geom2)
Same goes for ST_Contains, ST_Overlap etc.
Hope that helps,
Regina
From: postgis-users-bounces at postgis.refractions.net on behalf of Mark Cave-Ayland
Sent: Sun 9/9/2007 4:30 PM
To: PostGIS Users Discussion
Subject: Re: [postgis-users] ST_<function> vs <function>
On Sun, 2007-09-09 at 16:03 -0400, Stephen Woodbridge wrote:
> Hi all,
> I seem to have missed reading some vital post or something.
> What is the difference between ST_<function>() and <function>()?
> Is this just a renaming for namespace issues?
> Are the <function>() names deprecated?
> Are there other benefits to this renaming?
> Please explain or point me to the relevant docs.
> Thanks,
>    -Steve
Hi Stephen,
I don't remember there being much discussion about this, but the
relevant commit can be found here:
http://postgis.refractions.net/pipermail/postgis-commits/2007-June/000074..html. In short, the old function names are deprecated, and new applications should start to use the ST_ prefix functions instead.
ATB,
Mark.
ILande - Open Source Consultancy
http://www.ilande.co.uk <http://www.ilande.co.uk/>
postgis-users mailing list
postgis-users at postgis.refractions.net
http://postgis.refractions.net/mailman/listinfo/postgis-users
The substance of this message, including any attachments, may be
confidential, legally privileged and/or exempt from disclosure
pursuant to Massachusetts law. It is intended
solely for the addressee. If you received this in error, please
contact the sender and delete the material from any computer.
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20070910/2499d562/attachment.html>
