[postgis-users] Distance between two points...
Kevin Neufeld
kneufeld at refractions.net
Mon Sep 10 20:27:57 PDT 2007
Try this:
SELECT ST_Distance(a.location, b.location)
FROM points_tbl a, points_tbl b
WHERE a.id = 1000 AND b.id = 3029;
-- Kevin
Kevin Neufeld
Software Developer
Refractions Research Inc.
300-1207 Douglas St.
Victoria, B.C., V8W 2E7
Phone: (250) 383-3022
Email: kneufeld at refractions.net
Chris Jewell wrote:
> -----BEGIN PGP SIGNED MESSAGE-----
> Hash: SHA1
> Hi all,
> So, I need to find the distance between two point referred to by unique IDs. I was
> trying to do something like:
> SELECT distance((SELECT location FROM points_tbl WHERE id=1000),(SELECT location FROM
> points_tbl WHERE id=3029));
> However, it appears that you cannot supply a query result as the argument to a
> function. I rather suspected this before I started ;-). Is there another way to
> return such a distance without having to write a function that copies the relevant
> location geometries into variables, and then uses the distance function?
> Many thanks,
> Chris
> Chris Jewell, BSc(Hons), BVSc, MRCVS
> Dept of Maths and Statistics
> Fylde College
> Lancaster University
> Lancaster
> Lancs
> LA1 4YF
> -----BEGIN PGP SIGNATURE-----
> Version: GnuPG v1.4.6 (GNU/Linux)
> Comment: Using GnuPG with Mozilla - http://enigmail.mozdev.org
> iD8DBQFG5chZtbYC54ephxMRAhSuAKCvu+Kf3+RWf/L1A6mibRWYsg38sACglPWj
> xE8OkX+CabnqZaH/tX/SgSo=
> =jgof
> -----END PGP SIGNATURE-----
> postgis-users mailing list
