[postgis-users] Distance between two points...
Chris Jewell c.jewell at lancaster.ac.uk
Mon Sep 10 15:42:47 PDT 2007
-----BEGIN PGP SIGNED MESSAGE-----
Hash: SHA1
Hi all,
So, I need to find the distance between two point referred to by unique IDs.  I was
trying to do something like:
SELECT distance((SELECT location FROM points_tbl WHERE id=1000),(SELECT location FROM
points_tbl WHERE id=3029));
However, it appears that you cannot supply a query result as the argument to a
function.  I rather suspected this before I started ;-).  Is there another way to
return such a distance without having to write a function that copies the relevant
location geometries into variables, and then uses the distance function?
Many thanks,
Chris
Chris Jewell, BSc(Hons), BVSc, MRCVS
Dept of Maths and Statistics
Fylde College
Lancaster University
Lancaster
Lancs
LA1 4YF
-----BEGIN PGP SIGNATURE-----
Version: GnuPG v1.4.6 (GNU/Linux)
Comment: Using GnuPG with Mozilla - http://enigmail.mozdev.org
iD8DBQFG5chZtbYC54ephxMRAhSuAKCvu+Kf3+RWf/L1A6mibRWYsg38sACglPWj
xE8OkX+CabnqZaH/tX/SgSo=
=jgof
-----END PGP SIGNATURE-----
