[postgis-users] [Spatial Query] Experiencing difficulties with Postgis, Google Maps and EJB3.
Paul Ramsey
pramsey at refractions.net
Tue Sep 11 09:29:47 PDT 2007
You've got Contains(point, polygon) in this, which will always return
nothing... flip your contains arguments around.
P
easyCity Team wrote:
> Hi guys,
> I'm trying do do a simple spatial query using PostGIS 1.1.2, Google Maps
> and EJB3... but it gets pretty frustrating :) Probably because I'm new
> to PostGIS.
> I would like to get all the points of interest that are in a
> rectangular area (the visible map area for the user).
> My POI are stored using a custom projection with the SRID 101 in my
> database.
> The map bounds are in latitude and longitude (I have 2 points :
> southWest and sorthEast).
> First, I red postgis documentation (§3.3) and tried to perform a native
> query using a postgresql client :
> select poi_gid, astext(geometry) as geom
> from poi AS p
> where transform(
> GeomFromText(
> 'POLYGON((
> 48.88190472849405 2.3015928268432617,
> 48.88190472849405 2.3398303985595703,
> 48.86417836241082 2.3015928268432617,
> 48.86417836241082 2.3398303985595703,
> 48.88190472849405 2.3015928268432617))',
> 4326)
> , 101) && p.geometry
> and Contains(p.geometry,
> transform(
> GeomFromText(
> 'POLYGON((
> 4326)
> , 101) );
> I got no error but no result neither.
> Then I tried the EJB3 way (but I don't really know how to use the
> spatial.XXX methods - is there any documentation about it?):
> public String localSearch(String what, double northEastLat,
> double northEastLng, double southWestLat, double southWestLng) {
> // Get the projected coordinates - TODO: Use a nicer way,
> probably with the org.postgis.Point class
> String neStr = this.getProjectedPoint(northEastLat, northEastLng,
> 101);
> neStr = neStr.replace("POINT(", "").replace(")", "");
> String swStr = this.getProjectedPoint(southWestLat, southWestLng,
> 101);
> swStr = swStr.replace("POINT(", "").replace(")", "");
> double neX = Double.parseDouble(neStr.split(" ")[0]);
> double neY = Double.parseDouble(neStr.split(" ")[1]);
> double swX = Double.parseDouble(swStr.split(" ")[0]);
> double swY = Double.parseDouble(swStr.split(" ")[1]);
> System.out.println(swStr);
> System.out.println(neX);
> System.out.println(neY);
> // Query POI in the bounded area
> Query query = em.createQuery("SELECT p FROM POI p "
> + "WHERE spatial.X(p.location) >=:neX "
> + "AND spatial.X(p.location) <=:swX "
> + "AND spatial.Y(p.location) >=:swY "
> + "AND spatial.Y(p.location) <=:neY ");
> query.setParameter("neX", neX);
> query.setParameter("swX", swX);
> query.setParameter("swY", swY);
> query.setParameter("neY", neY);
> List<POI> poiResults = query.setMaxResults(20).getResultList();
> System.out.println("> " + poiResults.size());
> System.out.println(northEastLat + " " + southWestLng);
> System.out.println(northEastLat + " " + northEastLng);
> System.out.println(southWestLat + " " + southWestLng);
> System.out.println(southWestLat + " " + northEastLng);
> return "Hello";
> private String getProjectedPoint(double lat, double lng, int
> destProjId) {
> int srcProjId = 4326;
> String query = "select AsText(transform(GeomFromText('POINT("
> + lat + " " + lng + ")'," + srcProjId + ")," + destProjId
> Query q = em.createNativeQuery(query);
> return (String) q.getSingleResult();
> I know that this code could be significantly improved with more
> knowledge on the technologies (postgis and ejb3 spatial).
> Could you give me some tips and guidelines to help me out ?
> Best Regards
> Romain
> postgis-users mailing list
Paul Ramsey
Refractions Research
http://www.refractions.net
Phone: 250-383-3022
Cell: 250-885-0632
