[postgis-users] [Spatial Query] Experiencing difficulties with Postgis, Google Maps and EJB3.
easyCity Team
dev at easycity.com
Wed Sep 12 01:03:19 PDT 2007
Thank you Paul :)
I think I miss entered the coordinates in the POLYGON WKT.
I tried with :
select poi_name, astext(transform(geometry, 4326)) as geometry
from poi AS p
where
GeomFromText(
'POLYGON((
90 -180,
90 180,
-90 180,
-90 -180,
90 -180))',
4326)
&& transform(geometry, 4326)
and Contains(
GeomFromText(
'POLYGON((
90 -180,
90 180,
-90 180,
-90 -180,
90 -180))',
4326), transform(geometry, 4326) );
... and it did the job :)
Thanks again for your help.
Do you know what is the nicest way to do it with EJB3 and where I can
find documentation ?
I know only this place at the moment :
* http://svn.refractions.net/postgis/trunk/java/ejb3
http://lists.refractions.net/pipermail/postgis-users/attachments/20070131/c4ea64d4/hql.bin
Greetings
Romain
Paul Ramsey a écrit :
> You've got Contains(point, polygon) in this, which will always return
> nothing... flip your contains arguments around.
> P
> easyCity Team wrote:
>> Hi guys,
>> I'm trying do do a simple spatial query using PostGIS 1.1.2, Google
>> Maps and EJB3... but it gets pretty frustrating :) Probably because
>> I'm new to PostGIS.
>> I would like to get all the points of interest that are in a
>> rectangular area (the visible map area for the user).
>> My POI are stored using a custom projection with the SRID 101 in my
>> database.
>> The map bounds are in latitude and longitude (I have 2 points :
>> southWest and sorthEast).
>> First, I red postgis documentation (§3.3) and tried to perform a
>> native query using a postgresql client :
>> select poi_gid, astext(geometry) as geom
>> from poi AS p
>> where transform(
>> GeomFromText(
>> 'POLYGON((
>> 48.88190472849405 2.3015928268432617,
>> 48.88190472849405 2.3398303985595703,
>> 48.86417836241082 2.3015928268432617,
>> 48.86417836241082 2.3398303985595703,
>> 48.88190472849405 2.3015928268432617))',
>> 4326)
>> , 101) && p.geometry
>> and Contains(p.geometry,
>> transform(
>> GeomFromText(
>> 'POLYGON((
>> 4326)
>> , 101) );
>> I got no error but no result neither.
>> Then I tried the EJB3 way (but I don't really know how to use the
>> spatial.XXX methods - is there any documentation about it?):
>> public String localSearch(String what, double northEastLat,
>> double northEastLng, double southWestLat, double
>> southWestLng) {
>> // Get the projected coordinates - TODO: Use a nicer way,
>> probably with the org.postgis.Point class
>> String neStr = this.getProjectedPoint(northEastLat,
>> northEastLng, 101);
>> neStr = neStr.replace("POINT(", "").replace(")", "");
>> String swStr = this.getProjectedPoint(southWestLat,
>> southWestLng, 101);
>> swStr = swStr.replace("POINT(", "").replace(")", "");
>> double neX = Double.parseDouble(neStr.split(" ")[0]);
>> double neY = Double.parseDouble(neStr.split(" ")[1]);
>> double swX = Double.parseDouble(swStr.split(" ")[0]);
>> double swY = Double.parseDouble(swStr.split(" ")[1]);
>> System.out.println(swStr);
>> System.out.println(neX);
>> System.out.println(neY);
>> // Query POI in the bounded area
>> Query query = em.createQuery("SELECT p FROM POI p "
>> + "WHERE spatial.X(p.location) >=:neX "
>> + "AND spatial.X(p.location) <=:swX "
>> + "AND spatial.Y(p.location) >=:swY "
>> + "AND spatial.Y(p.location) <=:neY ");
>> query.setParameter("neX", neX);
>> query.setParameter("swX", swX);
>> query.setParameter("swY", swY);
>> query.setParameter("neY", neY);
>> List<POI> poiResults = query.setMaxResults(20).getResultList();
>> System.out.println("> " + poiResults.size());
>> System.out.println(northEastLat + " " + southWestLng);
>> System.out.println(northEastLat + " " + northEastLng);
>> System.out.println(southWestLat + " " + southWestLng);
>> System.out.println(southWestLat + " " + northEastLng);
>> return "Hello";
>> private String getProjectedPoint(double lat, double lng, int
>> destProjId) {
>> int srcProjId = 4326;
>> String query = "select AsText(transform(GeomFromText('POINT("
>> + lat + " " + lng + ")'," + srcProjId + ")," + destProjId
>> Query q = em.createNativeQuery(query);
>> return (String) q.getSingleResult();
>> I know that this code could be significantly improved with more
>> knowledge on the technologies (postgis and ejb3 spatial).
>> Could you give me some tips and guidelines to help me out ?
>> Best Regards
>> Romain
>> postgis-users mailing list
>> postgis-users at postgis.refractions.net
>> http://postgis.refractions.net/mailman/listinfo/postgis-users
