[postgis-users] UNION
RAVI KUMAR
ravivundavalli at yahoo.com
Wed Sep 12 06:10:41 PDT 2007
Hi Regina,
I am trying to have a UNION of two shapefiles.
shape A has code as attribute
shape B has info as attribute
I wish to have a result where
1. Both the shapes intersected portions will have both the attributes and
2. The portions which donot intersect have their portion represented as well,
with zero as value for the attribute information that is missing.
So the resultant shape AB will have 2 attributes Code and Info and
values as per intersection, or zero values for the attribute that doesnot intersect.
The resultant will also have corresponding geometries of intersected portions as polygons gernerated, and unintersected portions also modified as seperate polygons.
Please give me some lead to find proper SQL query.
Cheers
Ravi Kumar
"Obe, Regina" <robe.dnd at cityofboston.gov> wrote:
Ravi,
Still not quite clear what question you are trying to answer.
I am guessing that you are getting duplicates because you have a one to many going on here. But I'm not sure which is the one and which is the many.
Also you don't need coalesce here since that is only useful if you expect one of your fields to be null. In this case since you are doing an inner join, neither will be NULL. Or perhaps you don't want to do an inner join.
It might be that you really want to use the aggregate form of geomunion
Something like
SELECT strubuf.struclass, geomunion(geof.geometry) AS geofac
FROM geof INNER JOIN strubuf ON (geof.geometry && strubuf.geometry AND
intersects(strubuf.geometry, geof.geometry))
GROUP BY strubuf.struclass
Just a guess. But perhaps that doesn't answer the question you were trying to ask.
From: postgis-users-bounces at postgis.refractions.net [mailto:postgis-users-bounces at postgis.refractions.net] On Behalf Of RAVI KUMAR
Sent: Tuesday, September 11, 2007 6:26 AM
To: jump-users at lists.jump-project.org
Cc: postgis
Subject: [postgis-users] UNION
I have prepared a course material for training in Jump for Geoscientists.
Added a minerological theme in which the final output results in prospectivity map.
I have used Post-GIS where ever complex bullion operators are needed. This was done smoothly.
But Iam now held-up in UNION and Intersection. Jump gives an OVERLAY which equals intersection. But the problem needs both
Intersected portion and
Non intersecting portion together.
Followed the advise given on this list to get the result. But the result
OPENJUMP
1.Overlay Layers A, B
2. Make union of the result (to use as a mask)
3. A-Union and B-union and combine theses two layers
4. Add Overlay to this.
This does the work but you have duplicate geometries which are filled with different attributes in different instances.
POSTGIS:
Followinf the suggestions on the Postgis list I have tried this query.
SELECT strubuf.struclass, COALESCE(geomunion(strubuf.geometry,
geof.geometry), geof.geometry) AS geofac FROM geof INNER JOIN strubuf ON (geof.geometry && strubuf.geometry AND
intersects(strubuf.geometry, geof.geometry));
But this doesnt result in a table geofac
This is where I am..
But for this additional exercise every thing else is ready.
However Proof of Concept for Geoscientists lies in THIS.
Cheers
Ravi Kumar
Be a better Heartthrob. Get better relationship answers from someone who knows.
Yahoo! Answers - Check it out.
The substance of this message, including any attachments, may be confidential, legally privileged and/or exempt from disclosure pursuant to Massachusetts law. It is intended solely for the addressee. If you received this in error, please contact the sender and delete the material from any computer.
postgis-users mailing list
postgis-users at postgis.refractions.net
http://postgis.refractions.net/mailman/listinfo/postgis-users
Take the Internet to Go: Yahoo!Go puts the Internet in your pocket: mail, news, photos & more.
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20070912/584fe2ee/attachment.html>
