[postgis-users] UNION
Andreas Laggner
andreas.laggner at fal.de
Thu Sep 13 02:37:56 PDT 2007
Hi Ravi, Hi Regina,
it seems to me that Ravi wants to perform the same GIS-Operation as i
want - Ravi, perhaps look at the mails with "Union of 7 datasets" from
end of august.
Point 2 works good with a left join, but part 1 i did not get so far.
cheers Andreas
RAVI KUMAR schrieb:
> Hi Regina,
> I am trying to have a UNION of two shapefiles.
> shape A has code as attribute
> shape B has info as attribute
> I wish to have a result where
> 1. Both the shapes intersected portions will have both the attributes and
> 2. The portions which donot intersect have their portion represented
> as well,
> with zero as value for the attribute information that is missing.
> So the resultant shape AB will have 2 attributes Code and Info and
> values as per intersection, or zero values for the attribute that
> doesnot intersect.
> The resultant will also have corresponding geometries of intersected
> portions as polygons gernerated, and unintersected portions also
> modified as seperate polygons.
> Please give me some lead to find proper SQL query.
> Cheers
> Ravi Kumar
> */"Obe, Regina" <robe.dnd at cityofboston.gov>/* wrote:
> Ravi,
> Still not quite clear what question you are trying to answer.
> I am guessing that you are getting duplicates because you have a
> one to many going on here. But I'm not sure which is the one and
> which is the many.
> Also you don't need coalesce here since that is only useful if you
> expect one of your fields to be null. In this case since you are
> doing an inner join, neither will be NULL. Or perhaps you don't
> want to do an inner join.
> It might be that you really want to use the aggregate form of
> geomunion
> Something like
> SELECT strubuf.struclass, geomunion(geof.geometry) AS geofac
> FROM geof INNER JOIN strubuf ON (geof.geometry && strubuf.geometry AND
> intersects(strubuf.geometry, geof.geometry))
> GROUP BY strubuf.struclass
> Just a guess. But perhaps that doesn't answer the question you
> were trying to ask.
> *From:* postgis-users-bounces at postgis.refractions.net
> [mailto:postgis-users-bounces at postgis.refractions.net] *On Behalf
> Of *RAVI KUMAR
> *Sent:* Tuesday, September 11, 2007 6:26 AM
> *To:* jump-users at lists.jump-project.org
> *Cc:* postgis
> *Subject:* [postgis-users] UNION
> Hi,
> I have prepared a course material for training in Jump for
> Geoscientists.
> Added a minerological theme in which the final output results in
> prospectivity map.
> I have used Post-GIS where ever complex bullion operators are
> needed. This was done smoothly.
> But Iam now held-up in UNION and Intersection. Jump gives an
> OVERLAY which equals intersection. But the problem needs both
> Intersected portion and
> Non intersecting portion together.
> Followed the advise given on this list to get the result. But the
> result
> OPENJUMP
> 1.Overlay Layers A, B
> 2. Make union of the result (to use as a mask)
> 3. A-Union and B-union and combine theses two layers
> 4. Add Overlay to this.
> This does the work but you have duplicate geometries which are
> filled with different attributes in different instances.
> POSTGIS:
> Followinf the suggestions on the Postgis list I have tried this query.
> SELECT strubuf.struclass, COALESCE(geomunion(strubuf.geometry,
> geof.geometry), geof.geometry) AS geofac FROM geof INNER JOIN
> intersects(strubuf.geometry, geof.geometry));
> But this doesnt result in a table geofac
> This is where I am..
> But for this additional exercise every thing else is ready.
> However Proof of Concept for Geoscientists lies in THIS.
> Cheers
> Ravi Kumar
> Be a better Heartthrob. Get better relationship answers
> <http://us.rd.yahoo.com/evt=48255/*http://answers.yahoo.com/dir/_ylc=X3oDMTI5MGx2aThyBF9TAzIxMTU1MDAzNTIEX3MDMzk2NTQ1MTAzBHNlYwNCQUJwaWxsYXJfTklfMzYwBHNsawNQcm9kdWN0X3F1ZXN0aW9uX3BhZ2U-?link=list&sid=396545433>from
> someone who knows.
> Yahoo! Answers - Check it out.
> *The substance of this message, including any attachments, may be
> confidential, legally privileged and/or exempt from disclosure
> pursuant to Massachusetts law. It is intended solely for the
> addressee. If you received this in error, please contact the
> sender and delete the material from any computer. *
> postgis-users mailing list
> Take the Internet to Go: Yahoo!Go puts the Internet in your pocket:
> <http://us.rd.yahoo.com/evt=48253/*http://mobile.yahoo.com/go?refer=1GNXIC>
> mail, news, photos & more.
Dipl. Geoökologe Andreas Laggner
Institut für Ländliche Räume (LR)
Bundesforschungsanstalt für Landwirtschaft (FAL)
Institute of Rural Studies
Federal Agricultural Research Centre (FAL)
Bundesallee 50
D-38116 Braunschweig
Tel.: (+49) (0)531 596 5515
Fax: (+49) (0)531 596 5599
E-mail: andreas.laggner at fal.de
Homepage: http://www.lr.fal.de/
