[postgis-users] Intersection errors out with null directed edge
Andreas Laggner andreas.laggner at fal.de
Thu Sep 13 02:31:44 PDT 2007
Hi Chris,
as i had this errors i installed postgis with GEOS 3.0, and such an
errors never occurs again! I am not sure, but postgis 1.3.1 can be built
with GEOS 2.2 too......just run the query select postgis_full_version();
and check your version of GEOS.
cheers      Andreas
Chris Hermansen schrieb:
> Hi folks;
> I had this problem today:
> AssertionFailedException: EdgeRing::computePoints: found null Directed
> Edge
> I see in the archives that there are others who have suffered this, back
> in 2006 and then in 2005, but there don't seem to be any offerings of
> techniques to either repair the code or the data - and based on the
> error above, I'm not sure which is ultimately at fault.
> Does anyone have some more up-to-date thought on this?
> I'm running postgis-1.3.1 on Ubuntu with the packaged postgresql-8.2
> installed.
> Thanks in advance!
Dipl. Geoökologe Andreas Laggner
Institut für Ländliche Räume (LR)
Bundesforschungsanstalt für Landwirtschaft (FAL)
Institute of Rural Studies
Federal Agricultural Research Centre (FAL)
Bundesallee 50
D-38116 Braunschweig
Tel.: (+49) (0)531 596 5515
Fax: (+49) (0)531 596 5599
E-mail: andreas.laggner at fal.de
Homepage: http://www.lr.fal.de/
