[postgis-users] AsKML() how to create kml from postgis data
Maciej Skorczewski
maciej.skorczewski at procad.pl
Fri Sep 14 01:26:03 PDT 2007
Hi Jose !
how sql should looks like?
I use PHP. so i want to use it whit PostgreSql...
is there any doc. about this function?
Question about Python class...i am not python programer can you
describe my how i can use it?
thx :)
> Hi,
> On 9/14/07, Maciej Skorczewski <maciej.skorczewski at procad.pl> wrote:
>> How should i use AsKML() function to create KML files (w try show
>> postgis data in google maps nad google earth)
> The AsKML() function gives you the geometry in XML format (reprojected
> to WGS84, if that's needed). You need to add the other bits to make it
> into a full-fledged XML document. For each placemark, you get a
> <MultiGeometry></Multigeometry> bit. You need to add the rest of the
> XML, either working through the DOM, or just by creating the XML on
> the fly.
> I have a python class that we use to produce these maps. It's based on
> GDAL/OGR, Matplotlib and so on. It is commented in Spanish, but if
> there is demand, I can put it up in the PostGIS wiki page.
> Cheers,
> Jose
> postgis-users mailing list
Maciej Skórczewski
