[postgis-users] AsKML() how to create kml from postgis data
Jose Gomez-Dans
jgomezdans at gmail.com
Fri Sep 14 03:09:11 PDT 2007
Hi Maciej,
I sent you an e-mail, but your spam protection system wouldn't allow
the message to go through. If you have another address, I'll resend
it to you :)
On 9/14/07, Maciej Skorczewski <maciej.skorczewski at procad.pl> wrote:
> how sql should looks like?
Simply (and this is already quite advanced: you can use simplify() to
reduce the number of points in your vector data. Ours are very
detailed, and we don't want that on our KML files):
SELECT AS_KML(SIMPLIFY(the_geom,100)) from MY_TABLE;
> Question about Python class...i am not python programer can you
> describe my how i can use it?
You just write a small python program to use it. You should be able to
do the same with PHP.
Cheers,
José
