[postgis-users] How to get the centroid of an bounding box using st_extent
Paul Ramsey
pramsey at refractions.net
Tue Sep 18 21:59:03 PDT 2007
Well, clearly there's a bug to be fixed.
In the meanwhile, since these are just boxes,
makepoint((minx+maxx)/2, (miny+maxy)/2)
P.
On 18-Sep-07, at 8:56 PM, Charlie Savage wrote:
> It turns out that st_extent is hundreds of times faster than
> Envelope. But I run into a problem when using it:
> select st_extent('POINT(10 10)')
> "BOX(10 10,10 10)"
> But if you do this:
> select asText(centroid(st_extent('POINT(10 10)')))
> "GEOMETRYCOLLECTION EMPTY"
> Which is the same issue I mentioned a couple weeks ago where
> Envelope('POINT(10 10)') doesn't return a point like it should.
> So I'd like to use st_extent, but a need a way to get a valid point
> that represents the center of the bounds instead of an empty
> collection. How?
> Charlie
> postgis-users mailing list
