[postgis-users] How to get the centroid of an bounding box using st_extent
Charlie Savage
cfis at savagexi.com
Tue Sep 18 22:07:06 PDT 2007
Hi Paul,
> Well, clearly there's a bug to be fixed.
> In the meanwhile, since these are just boxes,
> makepoint((minx+maxx)/2, (miny+maxy)/2)
Right, makes sense. Except I couldn't find an api that actually lets
you get at the information in the Box2D.
But I just looked again, and in fact there is one I missed:
select xmax(extent('POINT(10 10)'))
select xmin(extent('POINT(10 10)'))
So cool - that will do the trick. Thanks.
As an aside, its not obvious to me how to actually fix this bug.
Somehow the conversion from Box2D/Box3D to geometry needs to figure out
if the bbox has 0 width and/or 0 height and if so create a Point instead
of a Polygon. Would a check for xmin=xmax work - it seems dubious since
these are floating point numbers. Does the precision stuff in Geos help
with this somehow (except this is in PostGis not Geos)? Anyway, just
curious. I'll file a bug report.
Thanks,
Charlie
> P.
> On 18-Sep-07, at 8:56 PM, Charlie Savage wrote:
>> It turns out that st_extent is hundreds of times faster than Envelope.
>> But I run into a problem when using it:
>> select st_extent('POINT(10 10)')
>> "BOX(10 10,10 10)"
>> But if you do this:
>> select asText(centroid(st_extent('POINT(10 10)')))
>> "GEOMETRYCOLLECTION EMPTY"
>> Which is the same issue I mentioned a couple weeks ago where
>> Envelope('POINT(10 10)') doesn't return a point like it should.
>> So I'd like to use st_extent, but a need a way to get a valid point
>> that represents the center of the bounds instead of an empty
>> collection. How?
>> Charlie
>> postgis-users mailing list
>> postgis-users at postgis.refractions.net
>> http://postgis.refractions.net/mailman/listinfo/postgis-users
Type: application/x-pkcs7-signature
Desc: S/MIME Cryptographic Signature
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20070918/10e415d8/attachment.bin>
