[postgis-users] Making a line from points
David Potts
dave.potts at pinan.co.uk
Wed Sep 19 00:04:54 PDT 2007
hi List,
I am trying to make a linestring from a serries of points, I have tried
things like
update linetable set the_geom=makeline(select the_geom from points_table);
witch did'nt work, having looked at the documentation for making making
linestrings (addpoint,makeline, etc) and seen a previous example from
(http://postgis.refractions.net/pipermail/postgis-users/2005-February/006916.html)
SELECT MakeLine(the_geom) FROM ( SELECT the_geom FROM points
ORDER BY time ) foo;
I am still confused, I can't see how the last example is designed to work!
So if I have table called bar with an empty linestring geometry column and
I have another table foo with a series of valid point geometry entires,
how do I populate bar from foo?
David
Any views expressed in this message are those of the individual sender,
except where the sender specifically states them to be the views of the
Pinan Software
