[postgis-users] How to get the centroid of an bounding box using st_extent
Charlie Savage
cfis at savagexi.com
Wed Sep 19 12:37:19 PDT 2007
Hi Martin,
> Charlie, this is not a problem. Floating point rounding error only
> comes into play when you are doing computations using numeric
> operations. Extent computation only uses comparison operations, and
> these are exact.
Ah - that's interesting.
So if a BBox is computed for a geometry and it has the
> max and min x and y being exactly the same, it can be determined to be a
> Point, with no worry about error. (Conversely, if a geometry is not a
> point, it must have at least two coordinates with different Xs or Ys,
> and so its BBox will have a non-zero extent.
Thanks for the information. Ok, then I'll see if I can fix up the bbox2
to geometry conversion so it returns a point if either xmin=xmax or
ymin=ymax. Currently it returns an invalid polygon - same problem that
envelope had.
Charlie
Type: application/x-pkcs7-signature
Desc: S/MIME Cryptographic Signature
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20070919/35645f93/attachment.bin>
