[postgis-users] How to get the centroid of an bounding box using st_extent
Paul Ramsey
pramsey at refractions.net
Wed Sep 19 12:43:03 PDT 2007
Charlie Savage wrote:
> Hi Martin,
>> Charlie, this is not a problem. Floating point rounding error only
>> comes into play when you are doing computations using numeric
>> operations. Extent computation only uses comparison operations, and
>> these are exact.
> Ah - that's interesting.
> So if a BBox is computed for a geometry and it has the
>> max and min x and y being exactly the same, it can be determined to be
>> a Point, with no worry about error. (Conversely, if a geometry is not
>> a point, it must have at least two coordinates with different Xs or
>> Ys, and so its BBox will have a non-zero extent.
> Thanks for the information. Ok, then I'll see if I can fix up the bbox2
> to geometry conversion so it returns a point if either xmin=xmax or
> ymin=ymax. Currently it returns an invalid polygon - same problem that
> envelope had.
Hmmm... for an linear envelope would returning a linestring not make
more sense?
> Charlie
> postgis-users mailing list
Paul Ramsey
Refractions Research
http://www.refractions.net
Phone: 250-383-3022
Cell: 250-885-0632
