[postgis-users] RE: Question: How can I improve the performance of the function DISTANCE_SPHERE?
Obe, Regina
robe.dnd at cityofboston.gov
Mon Sep 24 09:37:40 PDT 2007
What area does your data cover? Does it cover the whole world or just a
limited region like a country? If you can transform to a meter based
projection, that would be the most efficient. Taht won't work
unfortunately if you need to cover the whole world. In which case you
may want to dissect your data into different quadrants and project each
separately.
Also would be helpful if you could show us the Explain analyze of your
query.
something like
EXPLAIN SELECT ... if explain analyze takes too long.
or
EXPLAIN ANALYZE SELECT .....
So we can see what indexes it is using etc. EXPLAIN Analyze would be
more informative, but sounds like it would take too long.
Hope that helps,
Regina
From: postgis-users-bounces at postgis.refractions.net
[mailto:postgis-users-bounces at postgis.refractions.net] On Behalf Of
Reichle, Florian
Sent: Monday, September 24, 2007 12:19 PM
To: postgis-users at postgis.refractions.net
Subject: RE: Question: How can I improve the performance of the function
DISTANCE_SPHERE?
i have tried this at my DB, but the query is even slow:
SELECT distinct point.field1, point.field2
FROM tab_point point LEFT JOIN
(SELECT point.field1 as pfield1, point.field2 as pfield2
FROM tab_point point, tab_line line WHERE
Expand(line.the_geom, 0.01) && point.the_geom AND
(DISTANCE_SPHEROID(point.the_geom, StartPoint(line.the_geom),
'SPHEROID["WGS 84",6378137,298.257223563]') < 50.00 OR
DISTANCE_SPHEROID(point.the_geom, Centroid(line.the_geom),
DISTANCE_SPHEROID(point.the_geom, EndPoint(line.the_geom),
'SPHEROID["WGS 84",6378137,298.257223563]') < 50.00) ) As ce
ON (ce.pfield1 = point.field1 and ce.pfield2 = point.field2)
WHERE ce.pfield1 IS NULL;
I'm thinking you are looking for
"All points whose closest line is > 50 meters away" which doesn't
require a slow cartesian product. --> Yes, that's right. I' am searching
for all points whose closest line is > 50 meters. But how is the trick
do not use the
cartesian product?
I have many datas in the DB and it takes moren than 10 hours.
Date: Mon, 17 Sep 2007 15:38:08 -0400
Subject: RE: [postgis-users] Question: How can I improve the
performance of thefunction DISTANCE_SPHERE?
To: "PostGIS Users Discussion" <postgis-users at postgis.refractions.net>
Message-ID:
<53F9CF533E1AA14EA1F8C5C08ABC08D201979F8A at ZDND.DND.boston.cob>
Content-Type: text/plain; charset="iso-8859-1"
Florian,
Two points
1) You have a cartesian product here which is very slow with the
tab_point point, tab_line line but it sounds like from your description
of your desired result that may be intentional but its hard to tell.
Just thought I would point it out.
But I could read your question a couple of ways.
2)
In general NOT IN is intuitive but much slower than doing a left join.
Also I think you want to do a compound check. Try doing the following
instead
The below query should give you "all points who are > 50 meters away
from the closest starting point the psuedo closest line". Note I added
an Expand of a percent of a degree because it is not guaranteed your
point will be in the bounding box of the line and can still be within 50
meters but take that out if you want. Also just going by the startpoint
is faulty - it might be better to use Centroid() instead of startpoint
or you could do (centroid or startpoint or endpoint) combination check -
see the second example below.
If you could transform to a non-degree projection, that would be a lot
more efficient too and then you can use distance which would give you
distance from closest point on the line.
'SPHEROID["WGS 84",6378137,298.257223563]') < 50.00) As ce
---What I mean by combination check
Caveat - the above examples wors reliably only if field1 and field2 are
never null of your point table are never null. It would be better to use
the primary key of the table.
From: postgis-users-bounces at postgis.refractions.net on behalf of
Reichle, Florian
Sent: Mon 9/17/2007 11:04 AM
Subject: [postgis-users] Question: How can I improve the performance of
I use the function DISTANCE_SPHERE to get a metric unit how far is a
point away from a polygon. I have two tables, one for the points and one
for the polygons. The polygons are MULTILINES.
The result of the query must be a list of all points, which are to far a
away from any polygon. So I reduce in the first step the list with &&
which drop all points which are intersects with the geom of any polygon.
After that i must proof if the distance of the rest to far away.
Therefor I use the DISTANCE_SPHERE function. But at here I have the
problem with the speed of the query, because the function take to much
time to compare alle elements in the tables. Have someone any better
idea?
Here my example:
SELECT distinct point.field1, point.field2, line.field1, line.field2
point.field1 NOT IN (SELECT distinct point.field1, point.field2,
line.field1, line.field2 FROM tab_point point, tab_line line WHERE
point.the_geom && line.the_geom AND
'SPHEROID["WGS 84",6378137,298.257223563]') < 50.00 GROUP BY
point.field1, point.field2, line.field1, line.field2 from );
Greetz
The substance of this message, including any attachments, may be
confidential, legally privileged and/or exempt from disclosure
pursuant to Massachusetts law. It is intended
solely for the addressee. If you received this in error, please
contact the sender and delete the material from any computer.
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20070924/b581c2b8/attachment.html>
