[postgis-users] RE: Question: How can I improve the performance of the function DISTANCE_SPHERE?
Stephen Woodbridge woodbri at swoodbridge.com
Mon Sep 24 09:42:59 PDT 2007
Expand the points not the line, this is much faster and well product the
same results.
Also use distance() of distance_sphere() over distance_spheroid() as the
are fast in that order, if you need more exact results, the do
where ... and distance(...)<?? and distance_spheroid(...)<??
-Steve
Reichle, Florian wrote:
> Hi,
> i have tried this at my DB, but the query is even slow:
> SELECT distinct point.field1, point.field2
> FROM tab_point point LEFT JOIN
>             (SELECT point.field1 as pfield1, point.field2 as pfield2  FROM tab_point point, tab_line line WHERE
>  Expand(line.the_geom, 0.01)  && point.the_geom  AND
> (DISTANCE_SPHEROID(point.the_geom, StartPoint(line.the_geom), 'SPHEROID["WGS 84",6378137,298.257223563]') < 50.00 OR DISTANCE_SPHEROID(point.the_geom, Centroid(line.the_geom), 'SPHEROID["WGS 84",6378137,298.257223563]') < 50.00 OR DISTANCE_SPHEROID(point.the_geom, EndPoint(line.the_geom), 'SPHEROID["WGS 84",6378137,298.257223563]') < 50.00) ) As ce
>            ON (ce.pfield1 = point.field1 and ce.pfield2 = point.field2)
> WHERE ce.pfield1 IS NULL;
> I'm thinking you are looking for
> "All points whose closest line is > 50 meters away" which doesn't require a slow cartesian product. --> Yes, that's right. I' am searching for all points whose closest line is  > 50 meters. But how is the trick do not use the
> cartesian product?
> I have many datas in the DB and it takes moren than 10 hours.
> Date: Mon, 17 Sep 2007 15:38:08 -0400
> From: "Obe, Regina" <robe.dnd at cityofboston.gov>
> Subject: RE: [postgis-users] Question: How can I improve the
>         performance of  thefunction DISTANCE_SPHERE?
> To: "PostGIS Users Discussion" <postgis-users at postgis.refractions.net>
> Message-ID:
>         <53F9CF533E1AA14EA1F8C5C08ABC08D201979F8A at ZDND.DND.boston.cob>
> Content-Type: text/plain; charset="iso-8859-1"
> Florian,
> Two points
> 1) You have a cartesian product here which is very slow with the tab_point point, tab_line line but it sounds like from your description of your desired result that may be intentional but its hard to tell.   Just thought I would point it out.
> But I could read your question a couple of ways.
> 2)
> In general NOT IN is intuitive but much slower than doing a left join.  Also I think you want to  do a compound check.  Try doing the following instead
> The below query should give you "all points who are > 50 meters away from the closest starting point the psuedo closest line".  Note I added an Expand of a percent of a degree because it is not guaranteed your point will be in the bounding box of the line and can still be within 50 meters but take that out if you want.  Also just going by the startpoint is faulty - it might be better to use Centroid() instead of startpoint or you could do (centroid or startpoint or endpoint) combination check - see the second example below.
> If you could transform to a non-degree projection, that would be a lot more efficient too and then you can use distance which would give you distance from closest point on the line.
> DISTANCE_SPHEROID(point.the_geom, StartPoint(line.the_geom), 'SPHEROID["WGS 84",6378137,298.257223563]') < 50.00)  As ce
> ---What I mean by combination check
> Caveat - the above examples wors reliably only if field1 and field2 are never null of your point table are never null. It would be better to use the primary key of the table.
> ________________________________
> From: postgis-users-bounces at postgis.refractions.net on behalf of Reichle, Florian
> Sent: Mon 9/17/2007 11:04 AM
> To: postgis-users at postgis.refractions.net
> Subject: [postgis-users] Question: How can I improve the performance of thefunction DISTANCE_SPHERE?
> Hi,
> I use the function DISTANCE_SPHERE to get a metric unit how far is a point away from a polygon. I have two tables, one for the points and one for the polygons. The polygons are MULTILINES.
> The result of the query must be a list of all points, which are to far a away from any polygon. So I reduce in the first step the list with && which drop all points which are intersects with the geom of any polygon. After that i must proof if the distance of the rest to far away. Therefor I use the DISTANCE_SPHERE function. But at here I have the problem with the speed of the query, because the function take to much time to compare alle elements in the tables. Have someone any better idea?
> Here my example:
> SELECT distinct point.field1, point.field2, line.field1, line.field2 FROM tab_point point, tab_line line WHERE
> point.field1 NOT IN (SELECT distinct point.field1, point.field2, line.field1, line.field2 FROM tab_point point, tab_line line WHERE
> point.the_geom && line.the_geom AND
> DISTANCE_SPHEROID(point.the_geom, StartPoint(line.the_geom), 'SPHEROID["WGS 84",6378137,298.257223563]') < 50.00 GROUP BY point.field1, point.field2, line.field1, line.field2 from );
> Greetz
> postgis-users mailing list
