[postgis-users] RE: Question: How can I improve the performance of	function DISTANCE_SPHERE?
    Reichle, Florian
    florian.reichle at p3-gmbh.de
    Tue Sep 25 01:47:34 PDT 2007
Does it cover the whole world or just a
limited region like a country?
--> As an eample take Germany as country
If you can transform to a meter based
projection, that would be the most efficient.
--> How can I do this?
My EXPLAIN SELECT:
QUERY PLAN
Unique  (cost=18858475.73..18858492.79 rows=4 width=39)
  ->  Group  (cost=18858475.73..18858492.77 rows=4 width=39)
        ->  Merge Left Join  (cost=18858475.73..18858492.75 rows=4 width=39)
              Merge Cond: (("outer"."?column3?" = "inner"."?column3?") AND (point.poi_id = point.poi_id))
              Filter: (point.poi_name IS NULL)
              ->  Sort  (cost=86.94..89.03 rows=836 width=39)
                    Sort Key: (point.poi_name)::text, point.poi_id
                    ->  Seq Scan on navteq_poi point  (cost=0.00..46.36 rows=836 width=39)
              ->  Sort  (cost=18858388.80..18858392.28 rows=1394 width=39)
                    ->  Nested Loop  (cost=47.20..18858316.00 rows=1394 width=39)
                          Join Filter: ((expand(line.the_geom, 0.01::double precision) && point.the_geom) AND ((distance_spheroid(point.the_geom, startpoint(line.the_geom), 'SPHEROID("WGS 84",6378137,298.257223563)'::spheroid) < 50::double precision) OR (distance_spheroid(point.the_geom, centroid(line.the_geom), 'SPHEROID("WGS 84",6378137,298.257223563)'::spheroid) < 50::double precision) OR (distance_spheroid(point.the_geom, endpoint(line.the_geom), 'SPHEROID("WGS 84",6378137,298.257223563)'::spheroid) < 50::double precision)))
                          ->  Seq Scan on navteq_streets line  (cost=0.00..43075.15 rows=473815 width=85)
                          ->  Materialize  (cost=47.20..55.56 rows=836 width=71)
                                ->  Seq Scan on navteq_poi point  (cost=0.00..46.36 rows=836 width=71)
The EXPLAIN ANALYZE took to long. So I hope the information will help.
Thanks
Type: application/ms-tnef
Desc: not available
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20070925/13032af6/attachment.bin>
