[postgis-users] RE: Question: How can I improve the performance of function DISTANCE_SPHERE?
Obe, Regina robe.dnd at cityofboston.gov
Tue Sep 25 06:17:53 PDT 2007
Florian,
I'm not too familiar with Germany spatial ref systems so maybe some
postgis user in Germany would be best able to help you on that.  My
guess is an SRID between 31466 and 312469 may work for you  - below is
the query to see the descriptions of these)
SELECT * FROM spatial_ref_sys WHERE srid between 31466 and 31469
Now for transforming your data.  I your SRID of your existing data is -1
instead something like say 4326 (longlat WGS 84)  then you need to force
it into the right SRID using ST_SetSRID and then transform.
Let us say for example you made the mistake of importing your data with
SRID -1 -> Then to remedy the situation , you would do the following.
The below assumes 31466 is the projection you have decided for your
data.
SELECT AddGeometryColumn('public', 'navteq_poi', 'the_geom_germany',
31466, 'POINT', 2);
UPDATE navteq_poi  SET the_geom_germany =
ST_Transform(ST_SetSRID(the_geom, 4326), 31466);
CREATE INDEX idx_navteq_poi_the_geom_germany ON parceltime_2006 USING
gist (the_geom_germany);
If your SRID is already something other than -1, then you can simply
replace the second line with
UPDATE navteq_poi  SET the_geom_germany = ST_Transform(the_geom,31466);
Optionally if you don't need the old geom field for anything else, you
can drop your original geom field with a
SELECT DropGeometryColumn('public', 'navteq_poi', 'the_geom');
Repeat the above process for your line table except of course replacing
POINT with LINESTRING or whatever your current type is for the_geom.
Now looking at the below plan, it looks like you may be missing a couple
of useful indexes.  Make sure you have btree indexes on the following
fields
navteq_poi.poi_name
navteq_poi .poi_id
Then do a vacuum analyze
Then from there you can simply use
for older postgis
(Expand(point.the_geom_germany, 50) && line.the_geom_germany) AND
Distance(point.the_geom_germany, line.the_geom_germany) < 50
If you are using the newer version of Postgis (1.3.1) then you can
simplify the above further with
ST_DWithin(point.the_geom_germany, line.the_geom_germany, 50)
(Note if you are using an older version of postgis, you may have to
remove the ST_ from above and ST_DWithin may not exist)
Hope that helps,
Regina
From: postgis-users-bounces at postgis.refractions.net
[mailto:postgis-users-bounces at postgis.refractions.net] On Behalf Of
Reichle, Florian
Sent: Tuesday, September 25, 2007 4:48 AM
To: postgis-users at postgis.refractions.net
Subject: RE: Question: How can I improve the performance of function
DISTANCE_SPHERE?
Does it cover the whole world or just a
limited region like a country?
--> As an eample take Germany as country
If you can transform to a meter based
projection, that would be the most efficient.
--> How can I do this?
My EXPLAIN SELECT:
QUERY PLAN
Unique  (cost=18858475.73..18858492.79 rows=4 width=39)
  ->  Group  (cost=18858475.73..18858492.77 rows=4 width=39)
        ->  Merge Left Join  (cost=18858475.73..18858492.75 rows=4
width=39)
              Merge Cond: (("outer"."?column3?" = "inner"."?column3?")
AND (point.poi_id = point.poi_id))
              Filter: (point.poi_name IS NULL)
              ->  Sort  (cost=86.94..89.03 rows=836 width=39)
                    Sort Key: (point.poi_name)::text, point.poi_id
                    ->  Seq Scan on navteq_poi point  (cost=0.00..46.36
rows=836 width=39)
              ->  Sort  (cost=18858388.80..18858392.28 rows=1394
width=39)
                    ->  Nested Loop  (cost=47.20..18858316.00 rows=1394
width=39)
                          Join Filter: ((expand(line.the_geom,
0.01::double precision) && point.the_geom) AND
((distance_spheroid(point.the_geom, startpoint(line.the_geom),
'SPHEROID("WGS 84",6378137,298.257223563)'::spheroid) < 50::double
precision) OR (distance_spheroid(point.the_geom,
centroid(line.the_geom), 'SPHEROID("WGS
84",6378137,298.257223563)'::spheroid) < 50::double precision) OR
(distance_spheroid(point.the_geom, endpoint(line.the_geom),
precision)))
                          ->  Seq Scan on navteq_streets line
(cost=0.00..43075.15 rows=473815 width=85)
                          ->  Materialize  (cost=47.20..55.56 rows=836
width=71)
(cost=0.00..46.36 rows=836 width=71)
The EXPLAIN ANALYZE took to long. So I hope the information will help.
Thanks
The substance of this message, including any attachments, may be
confidential, legally privileged and/or exempt from disclosure
pursuant to Massachusetts law. It is intended
solely for the addressee. If you received this in error, please
contact the sender and delete the material from any computer.
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20070925/8f1a69c9/attachment.html>
