[postgis-users] is possible to use a subset of the srid table?
Kevin Neufeld
kneufeld at refractions.net
Fri Sep 28 10:05:23 PDT 2007
Perhaps instead of creating separate databases, you could create
separate schemas, all sharing the same PostGIS installation.
Kevin Neufeld
Software Developer
Refractions Research Inc.
300-1207 Douglas St.
Victoria, B.C., V8W 2E7
Phone: (250) 383-3022
Email: kneufeld at refractions.net
Ludovico Bianchini wrote:
> Hi,
> I need to create many database on a server.
> Every one has to be spatially enabled, so I must load postgis object
> in every one.
> I want to save disk space...
> My question is: if I modify spatial_ref_sys.sql taking only srid
> records that I need, could I find any problem (maybe there are
> functions which silently use that table??)?
> postgis-users mailing list
