[postgis-users] Problems installing PostGIS on Red Hat EL 5
Paragon Corporation
lr at pcorp.us
Tue Apr 1 22:39:42 PDT 2008
I seem to be having problems loading the Postgis library on a RHEL 5 box
PostgreSQL 8.3.1. I'm getting this error
ERROR: could not load library "/usr/lib/pgsql/liblwgeom.so":
/usr/lib/pgsql/liblwgeom.so: undefined symbol: GEOSTopologyPreserveSimplify
CONTEXT: SQL statement "SELECT postgis_lib_version()"
PL/pgSQL function "postgis_full_version" line 11 at SQL statement
When I run
select postgis_full_version()
(or any postgis function for that matter)
Not quite sure what I am doing wrong.
First issue - I decided to try out the new Yum repository for Postgresql and
it puts everything in a different location from what I'm used to so that may
be part of the problem.
After yum install I had Postgis 1.3.2 with 8.3 has that awful aggregate bug
that crashes the server) and it had Geos 2.3 CAPI (or whatever that was).
So to get around that, I decided to compile Postgis and Geos 3.0.0 from
scratch
Here were my basic steps
1. Download yum config from
http://yum.pgsqlrpms.org/reporpms/8.3/pgdg-redhat-8.3-2.noarch.rpm
2. rpm -ivh pgdg-redhat-8.3-2.noarch.rpm
3. yum install postgresql
4. yum install postgis
5. yum install postgresql-devel
--After configuring Postgresql - I did
wget http://geos.refractions.net/downloads/geos-3.0.0.tar.bz2
bunzip2 -c geos-3.0.0.tar.bz2 | tar xvf -
cd geos-3.0.0
./configure
make clean
make
make install
wget http://postgis.refractions.net/postgis-svn.tar.gz
tar xvfz postgis-svn.tar.gz
cd postgis-svn
./configure --with-pgsql=/usr/bin/pg_config
make clean
make
make install
All seemed to go fine until I queried and got that error above.
Any thoughts on the issue would be helpful.
Thanks,
Regina
